04-11-2022, 11:03 AM | #1 |
Grill swap
The pic is what I'm wanting to change to but has anyone swapped grills from a 88 to a 85? Is it just the grill or does the radiator support have to be changed? Also does the wiring have to be changed for the lights?
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
04-11-2022, 11:46 AM | #2 |
Re: Grill swap
Unfortunately, you're looking at way more than just a grille swap, the core supports are different too. That's an '89-91 grille/core support. If you want the '85-88 style grille, you'll need the '85-88 core support, headlight buckets, headlights and maybe the front wiring harness too.
1985 GMC Sierra Classic Chopped down wrongbed Cammed LH6 5.3/T56/3.90 Walker Tuned 5/8 drop US Mags |
04-11-2022, 03:52 PM | #3 |
Re: Grill swap
I wanting to change to that style pictured.
04-11-2022, 07:57 PM | #4 |
Re: Grill swap
5 years ago or so I bought a 1984 C10 with a lightly smashed front end. The u pull junk yard near me had a 1990 Suburban. So I used it to fix the truck. From what I remember I pulled the complete front core support (lights, grille) and the headlight harness from the donor Suburban.
It only has original paint once |
04-12-2022, 06:56 AM | #5 |
67-72 parts collector,…
Re: Grill swap
I wish you were closer.
I have that style (89-91 blazer/Suburban) core support and headlights. Shipping would kill the deal for sure.
04-12-2022, 07:14 AM | #6 |
Re: Grill swap
Just did the same to my 84 GMC. Original core support was bad under both batteries, and had a newer style in the shed for several years.
04-12-2022, 12:51 PM | #7 | |
Re: Grill swap
So basically I need: 89-91 Radiator support Headlight buckets Grill pieces HL harness.
04-13-2022, 01:01 PM | #8 |
Will the 89-91 radiator support fit right in or will you have to make some adjustments. I want to put the same grill on my 84?
Posted via Mobile Device |
04-13-2022, 02:37 PM | #9 |
Junior Member
Re: Grill swap
I put a 90 suburban on my 83. need core support. will bolt right in. would be helpful to have harness. at least for the lights connectors, not sure if its a must, i had complete suburban so I switched everything over.
04-13-2022, 05:33 PM | #10 |
Re: Grill swap
Ahh. Well, same thing just backwards. Gotta have the core support and everything. If you could find a parts truck/one in a junkyard, that'd be the most cost effective way
04-14-2022, 12:32 PM | #11 |
Re: Grill swap
I agree and am looking just haven't found any yet.
04-28-2022, 10:15 AM | #12 |
This is my first project and I don’t want to order stuff and have something missing. For the harness y’all said you need at least the light connectors. Would I just order light connectors for 90 suburban? Thanks
05-08-2022, 01:38 AM | #13 |
Re: Grill swap
Here is some info.
https://ck5.com/forums/resources/89-...rille-swap.19/ |
05-09-2022, 08:36 PM | #14 | |
Re: Grill swap
I'm starting on my 85 this week after scoring a 89 suburban rad support with the harness.
