05-01-2021, 11:38 PM | #1 |
Has anyone built a 4x4? I need pictures for my assembly
Also, does anyone know what this is?
05-02-2021, 03:01 PM | #2 |
But Found Her 25yrs Later!
Re: Has anyone built a 4x4? I need pictures for my assembly
Are you asking how to build a 4x4 with original 60's parts? Or with newer parts? Will you be keeping your original frame? Or putting your body on a newer frame? 1/2 ton or 3/4 ton?
Are you wanting disc brakes? Just a few things to think about.
05-02-2021, 03:53 PM | #3 |
Every nut and bolt original from factory.
05-02-2021, 05:06 PM | #4 |
Best to find someone "improving" an original and get all the parts they remove. Lots out there consider the original running gear on a 60-66 4x4 to be suitable only for a boat anchor. (That is another question for a very different thread and really does not have a correct answer, only opinions). Anyway, that is the person you need to find. The parts are out there, and it can be done. Just takes patience, time and money.
Good luck, Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
05-02-2021, 05:30 PM | #5 |
Then I'm guessing you're going to be looking for a original 4x4 so the VIN's are original to a 4x4?
Or do you already have an original 60's 4x4 that you are going to be restoring to original?
05-02-2021, 05:48 PM | #6 |
Sorry guys, I guess I should be more specific. I own 4x4 and sent it to the paint shop and it finally came back 3 years later. Now it's time top put it together and I want to make sure and do it right.
05-02-2021, 06:17 PM | #7 |
Yes, that helps....
Besides you asking for pictures, there is a few threads that might help you. The "Most Original Truck in Existence", the "4x4's Gone Wild" and perhaps some of the 4x4 build threads here: https://67-72chevytrucks.com/vboard/...play.php?f=197 . Take some pictures of what you have of the areas of concern, and we might know of a thread that discusses that question.
05-02-2021, 07:38 PM | #8 | |
05-02-2021, 07:59 PM | #9 |
Sorry, misunderstood the question, disregard my first post.
The factory assembly manual (available from all the usual vendors) has good info on correct exaust, including 4x4 specific differences. I was surprised for instance to find that mine ending before the rear axle was factory correct. Lots of other good info in that book that you will find very helpful. That's a very nice looking (and rare) truck. Glad you are giving it the factory restoration it deserves. Lots of great info on this site (they have helped me a lot). Looking forward to seeing how your project progresses. Tom
05-03-2021, 10:02 PM | #10 |
60-66 Nut
No, none of these trucks had dual exhaust from the factory, just a single exhaust. The muffler was not mounted to anything other than the pipe on each end. The exhaust pipe would have been hung from a number of flexible hangers. Sorry I don't have any pics. There are likely some on this forum somewhere.
05-04-2021, 07:47 AM | #11 |
Moderator
In this thread there is a pic from the walker catalog. http://67-72chevytrucks.com/vboard/s...d.php?t=585245
A factory style exhaust - https://www.ebay.com/itm/25449006537...AAAOSwlyBeKN1C And here it is installed - http://67-72chevytrucks.com/vboard/s...82&postcount=3
05-04-2021, 09:10 AM | #12 |
On a 4x4 , the muffler gets the only support. Theres a bracket on the frame that arches over it. Then a rubber/fiber strap combination 3-4 inchs long that hangs down to another bracket. There's a Sheetmetal like strap with a T bolt and a hook that support the muffler. So far what I'm finding is , Chevrolets don't seem to have a tail pipe , just a down turn off the muffler. GMCs however have a tailpipe on K series trucks. Ill try and get some pictures of my exhaust for you. Nice looking 60 by the way. Was it originally a Black truck ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
05-04-2021, 09:12 AM | #13 |
Best thing to do is buy an assembly manual , lots of factory illustrations to show you what went where
05-04-2021, 10:12 AM | #14 |
Moderator
Yep, if you don't have one of those your up against it.
05-04-2021, 10:18 AM | #15 | |
Thank you. |
05-04-2021, 10:19 AM | #16 |
Have you ever seen this before?
05-04-2021, 01:41 PM | #17 |
I dont believe thats from your truck , or at least Ive never seen one
05-04-2021, 01:44 PM | #18 |
Heres what I was talking about for the muffler clamp and support for the muffler and turn down for the tailpipe. Shows the tailpipe was used on 1405 and 1406 Panel and Suburban models but not pickups
05-09-2021, 03:19 PM | #19 |
go too my build thread, most all the info is there. never Seen that bar on my tk. have fun.
1961 chevy K10 my build is------------61K10 build |
