05-09-2019, 04:25 PM | #1 |
Wipers have a mind of their own.
I'm sure I am not alone with this problem. When turning on the wipers on my 1990 GMC 2500 single cab, they do not always work in the speed I select and when I go to turn them off, I sometimes have to turn off the ignition to get them to stop.
On top of this mess, the windshield washer motor does not work atop the lever when you push it forward. I jumped out the motor to the battery and the motor does work so I am thinking the wiper control lever assembly is either haunted or shot. Any thoughts? Thank you for any help. |
05-09-2019, 06:38 PM | #2 |
driving is in my blood
Re: Wipers have a mind of their own.
Wiper circut board under the hood.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
05-09-2019, 08:24 PM | #3 |
Had the same problem with my 1994,go get a new circuit board, bolts onto the wiper motor,easy to do.
05-09-2019, 08:38 PM | #4 |
You can remove it and look for some bad solder joints.
I did that with mine and just touched them with a hot iron and it has worked fine since. Been a couple of years now. Kim |
05-09-2019, 09:31 PM | #5 |
88-90 had a different wiper motor/circuit board. The circuit board is no longer available for the 88-90 trucks, but the 91+wiper motor is a direct swap. It will plug right in.
07-11-2021, 09:49 PM | #6 | |
Thanks. Thought mine was possessed
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 1965 Chevy C50 |
07-13-2021, 11:54 PM | #7 |
Had the same problem on my 1998 c1500.
Bad solder joints on circuit board. I just reflowed the joints and it's been good for a while now. If you don't want to mess with it you can buy a new board, I don't think there to expensive.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1998 chevy c1500 4.3L 5speed (My current driver) 2002 Chevy s10 4.3L auto 4x4 1971 mercury monterey wagon 400 auto To many projects! |
07-14-2021, 08:53 PM | #8 |
Mine's been acting up for a while now. I have the circuit board, just haven't put it in. I have to clear my windshield a few times before topping out of the valley in the morning. I hit the momentary mode and if it's acting up I get 7 swipes. Not 6, not 8, 7 every time. Other symptoms are put them on intermittent and they end up deciding to run fulltime at some point. Sometimes they don't park right. It takes a few tries. But it's a Chevy. Been that way about a year now, still gets me where I need to go. Still have wipers
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 07-15-2021 at 05:14 AM. |
07-15-2021, 02:37 AM | #9 |
70+ ( Old Skool Club )
Learned about this wiper cut out thing on a 1997 Silverado coming back from Las Vegas was 80 degrees when I left Vegas and hit one of the those common come out of nowhere blizzards just after coming off of the Arizona I15 and into Utah. Semis all over the road and I had no wipers. First and only time in my life I pulled off the road to spent the night and did in Beaver Utah. .Next morning no blizzard so headed out and 30 miles up the road was as clear and clean as a summer day and was clear all the way home. If I buy a GMT 400 now the first thing I do is put in a new pulse board.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-15-2021, 12:30 PM | #10 |
Yup, had same issue on our previous '99 Tahoe with same symptoms. Would not run always on speed selected and not always park correctly. Replaced the pulse / circuit board in the wiper for under $30. Not hard to do.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
07-15-2021, 12:52 PM | #11 | |
I had to change the one on my G20. The wiper motor is inside behind the dash all the way up top.
07-21-2021, 02:13 PM | #12 |
Who Me?
Same as all the above. I just swapped mine a month or so ago.
Steve 1997 Tahoe LT 4D 2WD (DD) 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
07-21-2021, 07:34 PM | #13 |
If I could buy one of these for the female species that would be worth more than 30 bucks after 25 years they still have, well you know! LOL!
