Old 02-21-2013, 02:40 AM   #1
Smitz70
Question Non AC blower motor Relay
Hey guys long time reader... 1st post.
I have read over the posts about this & all I can find are A/C setups.
I have a 1970 c10 (non AC) that has had the wiring "rearanged".
The wiring inside the truck is intact & I have a new fan switch. I know the resistor is inside the heater box.
My question is where is the relay on a Non AC truck?
There is, what appears to be a relay, above the fan motor on the engine side of the firewall; with a gorund tab screwed to the firewall and 3 wire connectors (labled L, B, & S).
Is this my fan relay? If so how is it wired?
I have one orange wire coming from the resistor through the firewall. Does this connect to the fan motor or a relay?
P.S. Pics are great, and I am color blind; so wire color may be hit or miss..
I know it's alot of questions.. Thanks in advance.
Smitz
Smitz70 is offline   Reply With Quote
Old 02-21-2013, 11:01 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Non AC blower motor Relay
Smitz
There isn't a relay on non A/C trucks. The orange wire connects directly to the blower motor.
LockDoc
Leon
Old 02-21-2013, 01:19 PM   #3
Smitz70
Cool. Thanks Lockdoc, for the quick reply. I dont know what that relay is for but if it is not for my fan I will not worry about it right now.
One more issue.. When I move the fan switch, I get 12v at high position, nothing on the other positions. Is this the resistor?
Old 02-21-2013, 03:39 PM   #4
LockDoc
LockDoc's Avatar
I would think so unless your new switch is faulty. There are 2 wire coils on the resistor board, see if one of them is broken. Gently pry the wiring plug off with a small screw driver, working from side to side. It takes a 5/16 nut driver to remove the two hex head screws
Leon.
Leon
Old 02-21-2013, 05:18 PM   #5
1970 C10 MJW
1970 C10 MJW's Avatar
im surprised you have been able to go almost 6 years without posting lol
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 02-21-2013, 09:01 PM   #6
Smitz70
I try to spend more time in the garage than on the internet.
I thank you guys for the prompt replys!
Whats the best source for the fan & motor, on the cheap?
Old 02-21-2013, 11:33 PM   #7
LockDoc
LockDoc's Avatar
O' Reileys or Autozone I guess.. The same unit was used for a lot of years and vehicles, Corvair even used the same exact one as our trucks.
LockDoc
Leon
blower, heater, non ac, relay, resistor
