02-26-2021, 10:10 AM | #226 |
Re: Orson the 49 GMC ~ Chris C.
I’m going to go carb on my 53 Packard Clipper Deluxe Sportster. You can’t reproduce that classic look with EFI.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
02-27-2021, 12:27 AM | #227 |
1. Today’s progress
2. What’s left
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 02-27-2021 at 11:32 AM. Reason: flipped pics |
03-01-2021, 10:54 PM | #228 |
1. we finally finished the engine harness today, all that’s left tomorrow is the fuse box
2. we also finished the firewall today.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 03-02-2021 at 11:05 AM. Reason: fliipped pics |
03-02-2021, 11:42 PM | #229 |
we started putting loom on the wiring today
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 03-03-2021 at 11:14 AM. Reason: flipped pics |
03-03-2021, 08:39 AM | #230 |
it's always suuuuper satisfying to watch loom turn a rats nest into simple perfection.
03-03-2021, 10:25 AM | #231 |
Yes it is!
03-03-2021, 11:39 AM | #232 |
Great progress! It's nice to get things under control.
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
03-03-2021, 01:12 PM | #233 |
Thank you
03-03-2021, 09:26 PM | #234 |
1. we begin building the fuse box
2. JP installing the fuel line Quick connects 3. fuel system done
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 03-04-2021 at 11:07 AM. Reason: flipped pics |
03-03-2021, 09:29 PM | #235 |
03-04-2021, 02:44 AM | #236 |
great stuff chris!
03-04-2021, 09:55 AM | #237 |
Thanks brother!
03-04-2021, 10:22 PM | #238 |
The fuel system is finished! We modified the universal 0-30 ohm sender and included it in the tank.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 03-05-2021 at 11:13 AM. Reason: flipped pics |
03-05-2021, 11:31 AM | #239 |
This is the look we’re going for!
03-05-2021, 10:26 PM | #240 |
This was the 04 and up PRND switch
This is the correct 99-03 PRND switch installed This is showing us putting the wire loom on the main harness Same Main harness finished
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 03-06-2021 at 11:25 AM. Reason: flipped pics |
03-05-2021, 10:29 PM | #241 |
Sender, lines and ground finished
Overall with finished fuel tank we pulled the clutch, so we could remove the compressor from the old bracket and mount it on Orson
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 03-06-2021 at 11:28 AM. Reason: flipped pics |
03-06-2021, 08:46 AM | #242 |
Excellent progress! I can't wait to see a shot of the finished wiring, all tucked into place. How many hours do you figure you guys have invested in just the wiring?
03-06-2021, 09:32 AM | #243 |
I’d say 20-25,but I’m not charging for this since I bought a harness that didn’t fit.
03-08-2021, 11:33 PM | #244 |
1-2. We got the fuze block wiring all loomed up
3. all the pulleys are back on and the belt is routed. Tomorrow the cooling system goes back on for the last time!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 03-09-2021 at 10:59 AM. Reason: flipped pics |
03-10-2021, 12:07 AM | #245 |
1. The problem, the tensioner pulley was to big and left no room for the hose
2. I solved it by going from a 3.5” pulley to a 3”. 3. The belt fitted correctly 4. we also did some more wire covering
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 03-10-2021 at 11:13 AM. Reason: flipped pics |
03-10-2021, 12:10 AM | #246 |
The relay sockets came in today, so we started building the fuse Block
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 03-10-2021 at 11:15 AM. Reason: flipped pic |
03-10-2021, 11:17 PM | #247 |
1. We got the fusebox finished
2. Here’s the backside 3. all 4 of the injector plugs on the driver’s bank were broken and wouldn’t stay on, wound up replacing them all. Also did some more Wire covering
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 03-11-2021 at 11:05 AM. Reason: flipped pics |
03-10-2021, 11:19 PM | #248 |
We chose a 2nd gen Durango 2nd row for this build
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 03-11-2021 at 11:06 AM. Reason: flipped pics |
03-11-2021, 08:44 AM | #249 |
oh shoot, that'll be a good seat. i like how the middle actually totally folds down vs an insert. more of buckets with a console vs a bench with an armrest.
03-11-2021, 09:48 AM | #250 |
That’s exactly the reason it was chosen, that and the width. These trucks will fit a 55” seat, this one’s 53”
