Old 06-30-2021, 10:18 PM   #1
HO455
HO455's Avatar
Suburban quarter replacement
I did some searching and found some threads on lower quarter replacement but, they were all from 2014 or older and I am wondering if some new replacement panel has come to market. The photos show what I am having to repair.
http://67-72chevytrucks.com/vboard/s...80#post4359780
http://67-72chevytrucks.com/vboard/s...d.php?t=577312
One shop I talked to wants to use a bed side to replace everything from the glass down. I don't know all of the differences between trucks and Suburban, but I'm not sure this would save any labor over doing two lower quarter patch panels. Someone else said that a Blazer side would work well and again i don't know the differences.
Any help or guidance would be appreciated.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
HO455 is online now   Reply With Quote
Old 07-01-2021, 07:39 AM   #2
FLYNAVY30
Re: Suburban quarter replacement
I cant help, but I'm in for the updates as mine has a fair amount of rust and bondo back there, and will have to be replaced at some point.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
FLYNAVY30 is offline   Reply With Quote
Old 07-01-2021, 08:31 AM   #3
polishspy
lmc # 38-7838 - behind driver door
lmc # 38-7802 and 38-7803 - rear quarters
The top part you may be able to just pop out from the inside
polishspy is offline   Reply With Quote
Old 07-01-2021, 01:45 PM   #4
HO455
HO455's Avatar
Thanks for the part numbers!
From the LMC picture it looks like I would also need #38-7270 in order to replace the entire wheel well lip. If so it looks as if it ends right before the fuel fill. Is that correct?
RIP Bob Parks.
Old 07-01-2021, 04:21 PM   #5
BigBird05
See Chip Foose, He can pull that dent out.
BigBird05 is offline   Reply With Quote
Old 07-01-2021, 05:11 PM   #6
CG
BlahBlahBlah
I dunno if Wes is back to selling parts. If so he's usually well stocked in burb replacement panels. You might give him a shout.
Monroe Swap meet May 18-19.
Mike has the same spots for the NW guys he's had forever.
Lunch time BBQ at the spaces.
If you have stuff to sell bring it along.
If you have a question PM stllookn (Mike) here via the board.
https://67-72chevytrucks.com/vboard/...d.php?t=851291
Old 07-01-2021, 08:04 PM   #7
pwdcougar
pwdcougar's Avatar
I ordered a bunch of patch panels for my burb build. The long piece between the door and wheel well looked good but wouldn't lay flat. One of the biggest problems was that between the three pieces none of the pieces lined up. The little concave wheel lip part was different on each piece! I've been told that a shortbed pickup side is a good match and can be made to fit. All of the LMC parts look like they won't go up high enough on the body below the window. IF the bed side will match up that might be your best bet.
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 07-02-2021, 01:48 AM   #8
HO455
HO455's Avatar
That's true but I would never get the dent out of my wallet afterwards.
RIP Bob Parks.
Old 07-02-2021, 01:52 AM   #9
HO455
HO455's Avatar
Wow thanks! That is good information.
RIP Bob Parks.
Old 07-02-2021, 01:55 AM   #10
HO455
HO455's Avatar
He has my first call for stuff I can't get locally for some time. He has always been good to me.
RIP Bob Parks.
Old 07-02-2021, 01:01 PM   #11
polishspy
Most likely, that is a new part they offer, when I was looking it was not an option so i just go the fron and back, but my arch was in decent shape.
Old 07-06-2021, 09:04 AM   #12
kev2809
low n' slo
kev2809's Avatar
whenever you find thr right patches make sure the wheel arch has the small indent around it. I overlooked that and noticed it after I burned it in, that it did not have that indent.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 07-06-2021, 09:12 PM   #13
HO455
HO455's Avatar
Are you referring to the groove the arrow is pointing at?
RIP Bob Parks.
Old 07-07-2021, 06:50 PM   #14
pwdcougar
pwdcougar's Avatar
One of the patch panels I got for this area (from Rockauto) didn't have the groove. The second one did BUT the groove didn't match the lower in between the door and wheel well or the rear quarter patches. It took a great deal of fabrication work to make the groove continuous between the three panels.
Paul
Old 07-08-2021, 08:20 AM   #15
HO455
HO455's Avatar
Thanks for the information. Oh boy! One more thing to watch out for.
RIP Bob Parks.
Old 07-08-2021, 12:46 PM   #16
kev2809
low n' slo
kev2809's Avatar
yup that groove. I still haven't found a solution as I haven't messed with my truck in a while. but I'm hoping to find a cut off of a suburban
-_--_--_ _________
Old 07-09-2021, 10:09 AM   #17
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
When I started buying panels for my wife's burb all burb specific pieces were non existent. No one makes a complete burb quarter so you would have to cut one off a clean tub. My plan is to use long bed bed sides for patches. I did find out that the front fender area behind the wheel is the same as the lower area behind the wheels on a burb in the rear. ( I believe it was shortbedclayton that pointed this out in his crew cab build) So get the lower fender patch and a good long bed bed side and you should be able to get fixed up. I have since gotten 4 out of 6 burb quarter pieces that hers needs. It really would make a good crew cab build.
Ryan
1969 Chevy milk truck
Old 07-09-2021, 10:11 AM   #18
FLYNAVY30
Originally Posted by Dieselwrencher View Post
When I started buying panels for my wife's burb all burb specific pieces were non existent. No one makes a complete burb quarter so you would have to cut one off a clean tub. My plan is to use long bed bed sides for patches. I did find out that the front fender area behind the wheel is the same as the lower area in front of the wheels on a burb. ( I believe it was shortbedclayton that pointed this out in his crew cab build) So get the lower fender patch and a good long bed bed side and you should be able to get fixed up.
Good tip!! I'm going to need that in the future.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
Old 07-09-2021, 01:05 PM   #19
HO455
HO455's Avatar
RIP Bob Parks.
Old 07-14-2021, 07:29 AM   #20
Dieselwrencher
I actually just got some long bed bed sides from Leon so I can use them as patches for the wife's burb. I just need some more of that time stuff to get to that.
Ryan
Old 07-17-2021, 12:43 PM   #21
HO455
HO455's Avatar
I am under the impression that there is a difference between the long bed and the Suburban sheet metal in the area between the rear part of the wheel arch and the end of the quarter panel. The bottom roll is at a steeper angle on a Suburban is what I was told.
In the photo below the red line indicates where the long bed bottom edge would be different if what I was told is true. The reason I am asking is I have read here where people have used short bed sides or Blazer sides but with no explanation as to why, which panel do pick. Like you I have the opportunity to get a long bed side but if it is a bunch more work it may be better for me to pass on it.
If it isn't too much trouble could take a couple of minutes and compare the sides you got from Leon with your Suburban and see it that is true? I know how the bottom edge attaches is different between the pickups and the Suburbans.
Thanks in advance for any assistance.
RIP Bob Parks.
Old 07-19-2021, 06:59 AM   #22
richard2717
Equal opportunity joke ofender
richard2717's Avatar
I got lucky and came across a rust free set of skins for when I get to that point on my panel truck. There are still some out there but tuff to find.
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 07-19-2021, 03:31 PM   #23
HO455
HO455's Avatar
Some guys have all the luck!
I missed one on CL a couple days after the wreck.
RIP Bob Parks.
Old 08-14-2021, 08:24 AM   #24
Dave
DND Trucks
Does anyone know if someone from this forum or one of the big parts suppliers has ever formally requested suburban quarter panels to be manufactured?
I realize that this would a significant investment, from engineering to manufacturing and the ROI would certainly have to be considered. What I'm thinking here, is a full length quarter skin that goes up to the window area and stops short of the tail section. As the tail section is already available, thus it might help keep the cost down.
With entire truck cabs, bedsides, floors, etc., available now, I'm thinking there's definitely a demand for such a product. Finding good usable suburban quarters off a donor vehicle for folks who need them, simply isn't an option anymore.
Dave is offline   Reply With Quote
Old 08-14-2021, 08:47 AM   #25
FLYNAVY30
I'm with you Dave. Unfortunately, I doubt the demand is there. Just look at how little traffic this side of the forum regularly gets. Theres probably only 2 dozen or so of us the regularly check in over here.
I posted a thread a year or so ago about the popularity of the Suburban as opposed to the rest of the vintage SUV market. It still floors me how under valued these things are, and how under utilized they are compared to Defenders and FJs in the vintage overloading scene.
I do wish the fenders were available, as both of mine are full of rust and bondo.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
