03-30-2021, 09:12 PM | #1 |
Left LED Turns signals don't work when headlight turned on.
69 Chevy C10. Direct wire headlights and LED Tail Lights/turn signals. LED s are about 15 months old.
When I turn headlights on dash shows turn signal on but not blinking. When headlights turned off turn signals work fine. Any thoughts as to where to start would be appreciated. |
04-01-2021, 06:17 AM | #2 |
Moderator
Re: Left LED Turns signals don't work when headlight turned on.
What kind of flashers do you have on the fuse panel? I ask because I just went thru this with mine (new build) and had to put in LED flashers with a ground to make them work. Also had to use the little black inverter plug they come with.
