Old 06-22-2021, 09:58 PM   #1
karlbenz
aftermarket heat and ac
I'd like to put ac in my 64 gmc. In the process I'd like to get a unit that has both heat and ac. I have just the basic heater and having to use defrost with the heat on isn't always ideal. Who has done this and are you happy with it?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10
1965 Chevy C50
karlbenz is offline   Reply With Quote
Old 06-23-2021, 12:53 AM   #2
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Re: aftermarket heat and ac
Vintage AC
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 06-23-2021, 08:25 AM   #3
Klas
Junior Member
Klas's Avatar
I used Auto Classic Air for both the '64 panel and the wife's '61 Apache. They provided a complete system with good instructions. If I do another conversion, I'll use them again.
Klas is offline   Reply With Quote
Old 06-23-2021, 11:38 AM   #4
Southcity
Southcity's Avatar
I have the Old Air "Hurricane" heat/AC system in my 66 for years now and it has performed flawlessly. It does a great job of heating/cooling my large Suburban and the fan is very powerful. They offer vehicle specific systems or universal. The vehicle specific systems fit nicely and appear stock. Their support/service has been very good over the years when/if I had questions or needed to troubleshoot anything.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 06-23-2021, 09:46 PM   #5
karlbenz
which hurricane did you go with? I see different models of each but not much explanation of the differences
1964 GMC K10
1965 Chevy C50
Old 06-23-2021, 10:38 PM   #6
AcampoDave
AcampoDave's Avatar
I have a Vintage air "sure fit kit" in my '66. I have regularly driven it in ambient temps around 110 degrees and still stay rather comfortable. Is it late model Silverado comfortable at those temps? No, but its decent. However, when outdoor temps are more moderate like in the 90's it's very comfortable. As for the heat/defrost part, it does work but I don't often need it. The a/c compressor runs on defrost because the unit only uses recirculated air.
I find the fan is a bit loud but I have tinnitus pretty bad and get irritated with noise anyhow so others may find it to be fine. (It's probably also par for the course when the fan is above the passenger's feet.)
I think the key to any of these systems is to have good insullation on the floor and firewall (with no open gaps or holes) and quality weatherstrip. Also be prepared to upgrade your cooling system. I had to get a better radiator and upgrade my fan to an 18 inch 5 blade clutch style.
Edit: one last detail...my truck is light colored. I think a dark truck would be an oven in my climate no matter what.
AcampoDave is offline   Reply With Quote
Old 06-23-2021, 11:25 PM   #7
Southcity
Southcity's Avatar
I used the CAP-6610 (complete system) because I was starting from scratch but they have several systems available. I'd give them a call to discuss, they are very helpful and can make recommendations.
https://www.oldairproducts.com/produ...defrost-system
Old 06-24-2021, 08:53 AM   #8
Clyde65
Clyde65's Avatar
I have had Old Air Products since about 2001, has always worked flawlessly and has only needed periodic recharges.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-24-2021, 09:09 AM   #9
jbgroby
jbgroby's Avatar
Karl, What engine are you using? IF a 305-V-6 you will need to custom make a set of brackets to hold the compressor in the block, no one makes one. I have one that I will use in the future but maybe have a copy made at a local shop.
jbgroby is offline   Reply With Quote
Old 06-24-2021, 09:38 AM   #10
karlbenz
i have a 383 in it. doing a serpentine belt set up soon. have most the parts now
1964 GMC K10
1965 Chevy C50
Old 06-24-2021, 10:29 AM   #11
Southcity
Southcity's Avatar
Also make sure you have an alternator that can handle the increased amperage (the AC/Heat/Defrost fans are a big draw) especially if you also have a stereo, electric cooling pusher/puller fans etc.
Old 06-24-2021, 07:19 PM   #12
karlbenz
I'm dropping my alternator off in the morning to get it beefed up and one wire it
1964 GMC K10
1965 Chevy C50
Old 06-24-2021, 09:25 PM   #13
The Rocknrod
Moderator
The Rocknrod's Avatar
I would use a three wire. - http://www.madelectrical.com/electri...hreewire.shtml
Old 06-25-2021, 07:37 PM   #14
AcampoDave
AcampoDave's Avatar
That was a good read. No doubt the 3 wire was the OE choice of good reason.
Old 06-26-2021, 09:39 AM   #15
The Rocknrod
Moderator
Yes exactly. I have a 100 amp 3 wire in mine. With the ground it's actually a four wire.
Oh and I'm using the Old Air system too. The footprint (size), CFM and the control panel all sold me.
Old 07-23-2022, 06:52 PM   #16
karlbenz
A year later and I finally got my serpentine belt system installed. I'm leaning towards this here https://www.oldairproducts.com/produ...omplete-system
1964 GMC K10
1965 Chevy C50
Old 07-24-2022, 11:40 AM   #17
The Rocknrod
Moderator
What is your plan on the side fittings?
Old 07-24-2022, 12:51 PM   #18
karlbenz
Not really sure. Don't know much about this. Is there a better model for our trucks?
1964 GMC K10
1965 Chevy C50
Old 07-24-2022, 01:03 PM   #19
The Rocknrod
Moderator
Yes, they have a rear exit that uses the firewall heater opening already on the firewall.
You can search their website by year make model and it will show.
Old 07-24-2022, 07:57 PM   #20
karlbenz
They all say lower, upper or side fittings?
1964 GMC K10
1965 Chevy C50
Old 07-24-2022, 08:44 PM   #21
The Rocknrod
Moderator
Download the catalog. https://www.oldairproducts.com/articles/pdfcatalog
Around page nine it shows the various exits. And on page 31 or so our series trucks. Also on Monday you can call them to be sure. You won't be making any decisions here anyway.
Old 07-24-2022, 09:10 PM   #22
karlbenz
Nice, Thanks for the link
and here it is https://www.oldairproducts.com/produ...defrost-system
1964 GMC K10
1965 Chevy C50
Old 07-24-2022, 10:30 PM   #23
Accelo
Accelo's Avatar
Does OldAir have provisions for outside air inlet?
I noticed it mounts in the engine compartment and allows you to keep the glove box.
Vintage Air only used recirculated cabin air. No fresh air option like the factory system.
It mounts under the dash and makes everything very tight under there. Glovebox is only good for a few papers after the air box is installed.
Accelo is offline   Reply With Quote
Old 07-24-2022, 11:41 PM   #24
The Rocknrod
Moderator
No, mine doesnt.
