Old 02-02-2018, 04:16 PM   #76
pulltilbroke
pulltilbroke's Avatar
Re: Installing The NV4500 5 Speed Overdrive Transmission In The C-30
Awesome read, I plan on doing this swap in a similar fashion.
My question is is there enough to room between the case side and the hole location to possibly use a 12pt or socket head caps crew on the top holes threading into the bell?
Pics of that area would be awesome
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12
67 C-20,292,SM420,HO72
90 Dodge W250 Cummins,NV4500HD,205,D60/D80
93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70
pulltilbroke is offline   Reply With Quote
Old 02-02-2018, 04:46 PM   #77
LockDoc
The Older Generation
LockDoc's Avatar
It has been long enough that I can't remember for sure, but I don't think so, or I would probably have done it that way. I will have to double check on that tomorrow.
LockDoc
Leon
Old 02-02-2018, 08:31 PM   #78
Duck 37
Smile Re: Installing The NV4500 5 Speed Overdrive Transmission In The C-30
Would this conversion be right for a 72 C10 that has a factory 3 speed with a low center hump? Thanks
Duck 37 is offline   Reply With Quote
Old 02-02-2018, 11:50 PM   #79
LockDoc
LockDoc's Avatar
I'm not sure what the bearing retainer hole size is in the bell housing for the three speed. (of all the '67-'72 trucks I have owned I have never had one with a three speed) If it is the 5-1/8th inch hole it will work just like mine did. The low center hump will not work. You would have to trim out the low and bolt in a high hump. Not really a big deal.
LockDoc
Leon
Old 02-03-2018, 08:24 AM   #80
Duck 37
Thanks for the reply, 3 speed works fine but column shifter is not dependable and gearing is a little low for the highway. Love the down to earth info you offer . Thanks again
Old 02-04-2018, 12:44 AM   #81
pulltilbroke
Well, just scored the correct bell for this conversion/work. By the way did you get time to go snap any pics of the back side of the ear?
Old 02-04-2018, 09:44 AM   #82
Richard2112
Richard2112's Avatar
If you are referring to running a bolt in from the case side of the transmission (the upper bolts) then I'm pretty sure there isn't enough clearance for the bolt head. In this picture, you'll see that I didn't drill all the way through on the final size because the side of the drill bit would have cut into the side of the trans case. I knew this because I drilled through with the smaller pilot bit and left the bit through the hole, then measured the clearance to the case.
Notice in the picture, only the small center hole goes all the way through...
Richard2112 is offline   Reply With Quote
Old 02-04-2018, 12:12 PM   #83
LockDoc
LockDoc's Avatar
I didn't take any pictures but there is not enough clearance on the trans case to put a bolt through.
LockDoc
Leon
Old 01-05-2021, 06:34 PM   #84
aotte1
Going to do this NV4500 install using stock bell housing, as outlined in this thread. This is a very helpful discussion. Below are starting photos. This application is 1966 GMC Suburban 4WD, divorced 221 TC. Bell housing is newer version. First photo is from thread. Circled holes are of interest as to how deep they can be. General rule on thread strength is, if they can be threaded as deep as diameter, then they will hold. In this case 1/2 bolt, with 1/2 thread depth will hold bolt strength. Also, will likely face top two holes in bell housing.
Again, thanks to Leon for sharing this information.
aotte1 is offline   Reply With Quote
Old 01-06-2021, 01:35 AM   #85
LockDoc
LockDoc's Avatar
Originally Posted by aotte1 View Post
Going to do this NV4500 install using stock bell housing, as outlined in this thread. This is a very helpful discussion. Below are starting photos. This application is 1966 GMC Suburban 4WD, divorced 221 TC. Bell housing is newer version. First photo is from thread. Circled holes are of interest as to how deep they can be. General rule on thread strength is, if they can be threaded as deep as diameter, then they will hold. In this case 1/2 bolt, with 1/2 thread depth will hold bolt strength. Also, will likely face top two holes.
No problem on posting the thread.
I'm not 100% sure but I think I drilled those top holes deep enough that they were all the way through the mounting ears of the transmission and starting to break through the back side. I didn't want to drill them deep enough that the drill would start pulling to the side and egg the hole out. The threads were pretty much the full thickness of the transmission ear.
LockDoc
Leon
Old 01-06-2021, 01:32 PM   #86
Just curious, would a gear vendors do the same thing but with less work? It would cost more I think but for the less skilled knuckle busters it might be an option? I was thinking about it for a 1970 K10 with a SM465 and my 1984 K30/SM465.
BTW, I have a 2003 Ram 2500/5.9 with the NV5600 and love it.
Old 01-06-2021, 07:00 PM   #87
LockDoc
LockDoc's Avatar
I am not at all familiar with the Gear Vendors overdrive. There is a ton of threads on that subject on the board so I would rather not get into that discussion in this thread, and keep it focused on the NV4500, thanks.
https://www.google.com/search?domain...D%3A1%3B&hl=en
LockDoc
Leon
Old 01-06-2021, 07:26 PM   #88
Sorry, didn’t mean to hyjack your thread.
Old 01-09-2021, 07:31 PM   #89
Richard2112
Yes, when I did this I used grade 8 flanged bolts and did face the bolt surfaces at the top two holes.
Old 01-09-2021, 08:55 PM   #90
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
One of the awesome features of this site. Leon's experience is helping you with your installation.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-09-2021, 09:06 PM   #91
Richard2112
That is awesome. It was this thread that helped me get mine done also. Leons info has helped alot.
Old 01-09-2021, 09:31 PM   #92
Ol Blue K20
He is an awesome asset!
Dale
Old 01-15-2021, 10:35 PM   #93
aotte1
Just got mine done, using this method. Thanks Leon.
Old 01-16-2021, 12:41 AM   #94
LockDoc
LockDoc's Avatar
I'm glad the thread is still helping people with their projects. Thanks guys.
LockDoc
Leon
Old 08-04-2022, 05:17 AM   #95
aotte1
Getting ready to do another one.
Les
Old 08-04-2022, 09:00 AM   #96
LockDoc
LockDoc's Avatar
Les
Good deal Les! My transmission is still working flawlesly and I use the truck a lot. I need to change the throw out bearing because it is making noise, but other than that, no problems.
Hard to believe it has been 7 years since I did mine....
LockDoc
Leon
Old 08-04-2022, 12:30 PM   #97
70cst
70cst's Avatar
Looking good!!
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-12-2022, 07:14 AM   #98
Mickeymotormount
Mickeymotormount's Avatar
Great write-up. I've been looking for info about this swap not knowing it was here on this site.
Gonna be doing this to my '67 c20 with a 327. It will replace the old SM 420 that is currently in it.
John
1967 C20 2WD Longbed
2001 2500 HD 4X4 Extended cab long bed
Mickeymotormount is offline   Reply With Quote
Old 08-12-2022, 09:19 AM   #99
LockDoc
LockDoc's Avatar
Good deal!
You should be able to use all of your stock parts except maybe your bell housing. Your bell housing would be the same as the one I used except that the front bearing retainer hole is the small (4-11/16") diameter instead of the 5-1/8" needed for the NV4500 transmission. You can either have yours bored out to 5-1/8" or find a bell housing from a truck with the SM465 manual transmission. (1968 up)
Let us know how it goes.... Or post a link here if you start a thread on your swap.
LockDoc
Leon
Old 08-12-2022, 03:56 PM   #100
Mickeymotormount
Originally Posted by LockDoc View Post
Good deal!
LockDoc
Will do and thanks for all the info. Looks like it helped alot of guys out.
John
