05-26-2021, 02:38 PM | #26 |
Re: Control Arm Rubbing tire - solution 101 - found
I solved the same problem on my S10 by using a pair of 3/8" wheel spacers. Over 100k miles without issue. I had them made by a local machine shop with proper hub centering and wheel stud sizing. No generic parts house spacer.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-26-2021, 03:11 PM | #27 | |
Now I am aggravated as I noticed a split in the outer tie rod boot and the one on the passenger side is totally split. WTH? These things aren't a year old.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
05-26-2021, 03:35 PM | #28 | |
I hate hand sanding ! For the 3rd time ... rain tomorrow need to prime it again tonite .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
05-26-2021, 03:52 PM | #29 |
Could this part of my problem...
I have a P245/60/15 tire? Is the size a little to big adding to my issues? I am just trying to look at all possibilities. Thanks
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
05-26-2021, 05:04 PM | #30 |
Tire size should be moot.... It's the wheel lip that interferes w/the a-arm gutter.
05-26-2021, 05:12 PM | #31 |
True ... I am low on coffee
05-26-2021, 07:10 PM | #32 |
The reason behind the one drop spindle mentioning does not increase width that is for stock 67 70 drum front brake measurement
71 72 disc is slightly wider so is the rear axle is slightly wider as well |
05-26-2021, 07:30 PM | #33 |
Here's a pic of mine , ignore the dust everything in the shop is covered in dust.
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 05-30-2021 at 07:20 PM. |
06-02-2021, 04:21 PM | #34 |
Ok ... so if I understand it correctly:
I have a 4" BS and if I go with a 3" BS it will pull the tire another inch outwards? Thanks
06-02-2021, 06:09 PM | #35 | |
The more aggressive you get, the harder it is on wheel bearings as a result from the additional weighted leverage of a steel wheel. Just a maint related item to keep in mind. Again..... Trimming the rain gutter is very common for the minimal clearance needed. It just needs to be done w/care in mind.
06-03-2021, 12:13 AM | #36 |
Maybe I'm wrong but it seems that if you go with less backspace, in this case an inch, wouldn't it bring the face of the hub inwards an inch? So if you wanted more clearance from the back side of the hub, 4.5" backspace would gain you a half an inch clearance?
06-03-2021, 12:19 AM | #37 | |
In other words, maybe my above post is incorrect. |
06-03-2021, 12:28 AM | #38 | |
67-72 parts collector,…
It’s a measurement from the wheel mounting surface to the inside edge of the wheel. Less backspacing moves the wheel out.
06-03-2021, 07:12 AM | #39 |
I just might go with a 7" wheel/tire combo in the front and 8" in the back. That would solve my problem plus I could decrease my BS without it going to far outwards.
06-03-2021, 09:03 AM | #40 | |
Be prepared because even 7" wheels sometimes get close enough that it requires a little clearance work on those porky a-arm gutters. The OE disc brake 6" wheels are usually the ones that clear w/o issue. Aftermarket 7" wheels w/spec'd back spacing should be good.
06-03-2021, 02:03 PM | #41 | |
06-03-2021, 02:33 PM | #42 | |
ADDING back-space means the wheel barrel would be moving closer to the source of your contact issue. Reducing back-space would mean moving it away from your contact issue. You want a 6-7" wheel w/less BS than your current 8" wheel. That shifts the contact point @ the wheel lip farther away from the a-arm gutter while keeping a similar outer track width.
06-03-2021, 02:42 PM | #43 | |
06-18-2021, 11:45 PM | #44 |
Did you ever resolve this issue?
06-19-2021, 03:19 PM | #45 |
I ordered two 7" rims with 3" BS. The tire dealer said I can use the exisitng tires on either a 8" or 7" rims.
