09-08-2013, 06:02 AM | #1 |
SA 56 build
Thought I may as well put a build thread up for our 56 3100
We bought the 56 last year after a bit of a rest from our last build (68 Camaro) Plans are for EFI, overdrive Auto trans, Air conditioning and get it sitting a bit lower Before After We are converting the pickup to RH drive. In South Australia if you want to do any mods to a US vehicle it has to be converted to RH drive. (Our Camaro is still LH drive so it has to be basically factory stock, right down to the radio!) Here's a few shots of the dash conversion and Front end conversion (Thanks to Romano, Mick & Scott for your help) Dash / interior before Dash / interior now Front end before Front end now Progress is a bit slow at the moment while I get some stuff finished around the house, but we'll get there.
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
09-08-2013, 11:21 AM | #2 |
Re: SA 56 build
Looks like a real clean truck to start with.
Keep the pics coming. Kim |
09-08-2013, 11:47 AM | #3 |
Re: SA 56 build
good to see you started a build thread.
very cool rh conversion, is that a rh drive dash? it's black and doesn't look like a modded stock lh dash.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-09-2013, 11:10 PM | #4 |
Re: SA 56 build
Yep, it was a fairly tidy unit to start with, no show winner but more than good enough for waht we want.
09-09-2013, 11:10 PM | #5 |
Re: SA 56 build
double post
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. http://67-72chevytrucks.com/vboard/s...d.php?t=595909 Last edited by Nev68; 09-09-2013 at 11:11 PM. Reason: double post |
09-09-2013, 11:12 PM | #6 | |
Re: SA 56 build
The dash is the original LH unit converted to RH by a very skilled friend of mine
09-10-2013, 01:00 AM | #7 |
Re: SA 56 build
nice progress on a really nice truck
http://http://67-72chevytrucks.com/v...d.php?t=489721 Last edited by Coupeguy2001; 09-10-2013 at 01:07 AM. |
09-30-2013, 06:46 AM | #8 |
Re: SA 56 build
Started to fit the lowered rear springs but noticed a couple of the pins (that go through the spring eyes) had fractures in them.
Ordered some new ones, hopefully they get to me by the weekend.
11-15-2013, 04:32 AM | #9 |
Re: SA 56 build
Finally got around to fitting the lowered rear springs and fitting some hub caps.
Here's a before ....and after with caps __________________
11-15-2013, 11:31 AM | #10 |
Re: SA 56 build
Looks good.
Kim |
12-05-2013, 03:48 PM | #11 |
Re: SA 56 build
Very Cool!
12-06-2013, 11:09 PM | #12 |
Re: SA 56 build
Thanks.
Got to get back into it.
12-30-2013, 11:41 PM | #13 |
Re: SA 56 build
WOW!! How hard was it to put speedo on pass side??
12-31-2013, 01:10 AM | #14 |
Re: SA 56 build
Well since I had the assistance of a skilled friend it was fairly easy
I can weld but I didn't trust myself on this one. Actually took him a week or so with a lot of measuring before cutting started. You can see that the angles of the dash are slightly different when comparing LH and RH sides. Some filler panels were made up to make the gauge "pod" blend into the dash. (Is "blend" the right word?) Some people make the dash out of fibreglass when converting from LH to RH, but I am lucky to have a skilled friend so my dash is all steel.
12-31-2013, 02:13 PM | #15 |
Re: SA 56 build
Ahh i see! Looks great man! I have a crazy idea been thinking about doing to my dash think gonna go thru with it Thanks!!
03-29-2014, 04:58 PM | #16 |
A320 Pilot/USAF Retired
Re: SA 56 build
Any updates on this cool truck?
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
03-29-2014, 11:09 PM | #17 |
Re: SA 56 build
Not too much happening due to some home renovation work.
Just started setting the fuel tank up and installing Vintage Air AC.
03-30-2014, 03:19 PM | #18 |
Re: SA 56 build
live gets in the way
was hoping to see progress on this build, my truk only took 8 yrs to finish your still ahead of my game
03-30-2014, 10:07 PM | #19 |
Re: SA 56 build
I know what you mean, unfortunately(?) there's more to life than playing with cars.
I would like to see if I can get it going this year so me, the bride, and dogs can go for a spin when the warm weather returns.
06-14-2014, 11:31 PM | #20 |
Re: SA 56 build
Been a while since I've updated but home renovations have had priority and unfortunately I've just lost my job (33 years with the same company!) so my main priority now is to get another job
Anyway still hasn't stopped me getting wood Just sanding for a nice finish Putting on some stain Just fitting the outside boards for the moment to support the bed on the chassis while I run new fuel lines and add a filler pipe I've gone for a satin finsh on the timber instead of high gloss as there will be the odd bale of hay and other bits and pieces thrown in the back (occasionally)
06-15-2014, 10:59 AM | #21 |
Re: SA 56 build
Bed wood looks real nice.
Good luck on the job search. Kim |
06-15-2014, 11:03 PM | #22 |
Re: SA 56 build
Thanks Kim
06-15-2014, 11:16 PM | #23 |
Re: SA 56 build
That shade of gray is gorgeous and goes well with the finish you have chosen for the bed. I had been thinking of something in a darker shade of gray for my build, but decided since mine will be NAPCO-esque when done, I would stick with the original turquoise and white instead.
Keep up the good work! -Joe |
06-16-2014, 05:21 AM | #24 | |
Re: SA 56 build
06-16-2014, 09:11 AM | #25 |
Re: SA 56 build
Nice color!
