05-14-2020, 09:58 AM | #1 |
Anyone Sell Metal Glovebox Liners?
Just Wondering If Anyone Sells Metal Or Aluminum Glove Box Liners For The 67-72 C10 Trucks. Thanks
Posted via Mobile Device |
05-14-2020, 10:09 AM | #2 |
Re: Anyone Sell Metal Glovebox Liners?
With as hard as they are to get into place, I would not think a metal one would work. At least for A/C trucks.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
05-14-2020, 10:10 AM | #3 | |
Thought about that! Would be difficult but not impossible. Before the thoughts of the metal one, I was thinking of taking a paper one and soaking it in Fiberglass Resin. What has stopped me is I noticed the re-pops are covered in some type of either wax or other preservative. Any insights with this would help. I am sure lots of folks are growing tired of that un-secure paper crap. |
05-14-2020, 02:57 PM | #4 |
Make It Half The Depth...
05-14-2020, 03:14 PM | #5 | |
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-14-2020, 03:19 PM | #6 |
Auto matic Corona Virus Proctection Device and Bug Out Materials!
05-14-2020, 06:46 PM | #7 |
05-14-2020, 06:52 PM | #8 |
All about them K’s
The .40 smith and Wesson is right at home in mine..
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
05-14-2020, 07:10 PM | #9 |
I think a plastic one that's flexible.enogh to fit in the opening. would work.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
05-14-2020, 09:15 PM | #10 |
Exactly what I mean. I have my old man's S&W highway patrolman 357 which did over 100k miles in the jockey box of his 70 with a box of shells. I would remember if it had fallen out.
05-14-2020, 10:22 PM | #11 |
You can build one. I built mine with a cardboard template then cut sheet metal.
05-15-2020, 12:12 AM | #12 |
That looks nice! Obviously not completely finished yet or maybe. Panel bonding adhesive is a thought for me.
Did you engineer yours to utilize the same screw holes? |
05-15-2020, 12:20 AM | #13 | |
How much to make me one of those????
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
05-15-2020, 07:27 AM | #14 |
I coated mine with Raptor bed liner, mine was not coated just plain cardboard, sealed the seams with polyurethane caulk, then Raptor inside and out.
05-15-2020, 08:51 AM | #15 |
Thank you. Yes it uses the factory attachments. I made it larger than the original. Big as possible. Added steel reinforcement. The original was toasted in a fire so I had nothing to go by. Made a cardboard template then cut sheet metal.
05-15-2020, 08:57 AM | #16 |
Much thanks for the comment. I make a lot of things for these trucks but haven't brought any to market yet. If your original glove box is out, get some poster board or cardboard (not corrugated) and start making the 4 sides until they all fit. Tape them together as you go. When you have a decent cardboard mock up, cut it at the seems so its one piece, lay it onto a sheet of metal and draw it out. Leave a little extra to fold over at the bends so you can easily rivet, or bolt together.
05-15-2020, 09:03 AM | #17 |
I put a layer of rubber inside mine and then did the reinforcement ribs, drilled and bolted it together. There are over a hundred pieces of hardware in my glove box assembly (nuts, bolts washers). I like the look of bolts. My truck has a bazillion of them so I made the bolts exposed in my glove box too. It's like a small security box.
05-15-2020, 09:08 AM | #18 |
That old model 28 is a sweet shooter . I had one years ago 4 inch barrel
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
05-15-2020, 09:16 AM | #19 |
Old Air offers Plastic for non-A/C trucks
https://www.oldairproducts.com/produ...7203-glove-box They do not however offer them for A/C equipped trucks though. Ahh some coffee, time to get back at it. Paul Jr @ GMCPauls |
05-15-2020, 09:24 AM | #20 |
This might give a better example of how to...
05-15-2020, 09:37 AM | #21 |
richard I would buy one of your . For non ac cab if your are interested please pm me
05-15-2020, 09:54 AM | #22 | |
Make a good template first, keeping the lines straight (cardboard, scissors and tape). A framing square comes in handy for making bend lines. make the main section with some extra metal at the front edges so you can double it over and have good connection points where it will bolt in. assemble the unit with minimum fasteners and push it into the glove box opening. It'll be tight but with minimun fasteners it should flex enough to push it through. Pull the unit forward into place and mark the bolt holes with a sharpie. Remove the unit, drill bolt hole a little over size and re-install. I built steel reinforcements across the bottom, first side to side then put two more at the back (those two are 90 degree brackets). Therer is also a rib below the box which shares the bolts with the flat steel member that runs side to side (inside the box) Apologies if that sounds confusing. I'm not real good at explaing something I did years ago, If you would like any clarification, I'll try to help. |
05-15-2020, 05:02 PM | #23 |
That project turned out awesome...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
05-15-2020, 05:09 PM | #24 |
Same here. She's my favorite.
05-15-2020, 05:22 PM | #25 |
Thank you OregonNed. I have some other projects in the works right now or I'd pull my glove box out and make a new template. Like most of my projects, it's overbuilt but I'll never need another. I'll look at making a new template when I finish the kit I'm designing as a replacement for the in-cab fuel tank behind the seat. That's a pretty cool kit too.
