02-14-2021, 01:19 PM | #1 |
Tachometer WILL **NOT** WORK W/ HEI DISTRIBUTORS
I am putting together a stock style dash with a tachometer. I would prefer the 8K Rpm limit style tach. Can anyone add information to why these tach's will not work with HEI?
Below is the provided disclaimer; For all of you fanatics out there, we have finally reproduced an original looking tachometer to fit correctly in you original instrument cluster with only minor modifications. Tach kit includes everything needed to convert to a tach dash; tachometer, lens, printed circuit, wiring harness, & 2 piece metal housing. WILL **NOT** WORK W/ HEI DISTRIBUTORS What I am more concerned with is if the tachometer will work with the computer output from the LS1 style computer. I see the addition of a pull down resister is required with some/all of the computer rpm connections. Rick |
02-14-2021, 03:23 PM | #2 |
Re: Tachometer WILL **NOT** WORK W/ HEI DISTRIBUTORS
That's a good question, every truck I've had with a tach or put a tach into did not matter whether or not it had HEI. Link to the maker
02-14-2021, 03:42 PM | #3 |
Since it's a "stock style" VS stock you can have the tach internals rebuilt with VDO internals and it will work with HEI. I had this done about 10 years ago, works well.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
02-14-2021, 08:06 PM | #4 |
I had the same concern when I decided to put a factory looking tach in my truck along with an HEI distributor.
Here is a quick explanation of why HEI is different: https://www.americanautowire.com/vie...c-distributor/ I ended up going with a go between interface box called TachMatch (model TM-03). It can take the signal from the HEI and converts it into the correct pulse pattern for the tach. https://technoversions.com/TachMatch.html#itworks I mounted the unit above the steering column behind the instrument cluster. They had great technical support too. Works flawlessly. On their website, it states that the unit can take a signal from the HEI or ECU; it has to correct pull-up resistor for the ECU. Hope this helps. -M |
02-14-2021, 08:20 PM | #5 |
Old member
I've done several trucks with stock GM HEI and never had a problem with the truck tach's. The last one I did worked for a while but quite. I sent it off and had it fixed. I added a 5amp fuse to it per the guy that fixed it and it's been fine ever since but no filters on any of them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-14-2021, 08:37 PM | #6 | |
02-14-2021, 09:14 PM | #7 | |
Old member
Here is the thread to mine. http://67-72chevytrucks.com/vboard/s...d.php?t=803315
02-17-2021, 10:25 PM | #8 |
I ran a factory tach in my 72 with an HEI for 20 years. Why exactly is it that it is not supposed to work? Lots of people have run them just like me.
Saskatoon, Saskatchewan Canada |
02-18-2021, 01:32 AM | #9 | |
The Older Generation
I read it that he will be using an aftermarket tach. Not all of them will work with an HEI out of the box. That is what he is referring to. LockDoc
02-18-2021, 02:14 PM | #10 |
I have a Brothers 8K tach upgrade. It's worked great with 3 different HEI distributors so far.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
02-18-2021, 02:22 PM | #11 |
Old member
Are you running the 5amp fuse? Mine has been good ever since I installed the fuse. It has been the only one that was aftermarket for me. All the rest have been old factory tach's and never had a problem with them.
02-18-2021, 04:27 PM | #12 |
The consensus seems to be they will work without major issues on the HEI. Unsure why they posted the disclaimer. Covering their A** is the only thing that comes to mind.
Rick |
02-19-2021, 08:52 PM | #13 |
Not yet, I keep meaning to install a fuse, but haven't yet. It's only been a couple of years now, don't want to rush into it.
02-19-2021, 10:01 PM | #14 | |
Old member
I never had either until this one.
