Old 03-21-2022, 07:52 PM   #51
wickedred
Re: Flat-Out Engineering front end?
Rack is mounted. Waiting on the bump steer kit. Then I will see if this deal is gonna work or make to the scrap pile.
Before anyone ask. No it’s not worth the effort.
1984 K5 Blazer 4x4. Because my daily driver needs to be a project too...
1971 C10. Auto Cross/Pro Touring Build. Project : I am gonna go broke with this one.
1970 Chevy LWB 4x4. 355, 4spd, Dana 44 front, Dana 60 rear, 35x12.50 tires... STOLEN
I will put a Turbo on anything with an engine if the $$$ is right. Once upon a time....
wickedred is offline   Reply With Quote
Old 03-22-2022, 07:49 AM   #52
Joyridin
Looking good! Hopefully you can figure the mess out to make it usable. I'm not sure who else makes them, but FatMan suspensions has their own style tie rod ends for that rack with an extended taper stud.
Joyridin is offline   Reply With Quote
Old 03-22-2022, 10:24 AM   #53
wickedred
I bought a Bump steer kit from Team Z Motorsports. It requires you to drill the spindle. I am determined to make it work.
Old 06-14-2022, 07:50 AM   #54
Joyridin
Having any luck getting the Flat-Out Wrong Engineering front end to work?
Old 06-18-2022, 12:20 PM   #55
wickedred
I have been sitting here looking at it for a few months. I can make it work with the current Rack and Pinion. Just leaning more towards the Sweet MFG servo racks. I seem to Hate Money and can't make up my mind what direction I am going with the C10 in general.
Old 06-18-2022, 10:38 PM   #56
SCOTI
SCOTI's Avatar
Hate sounds so harsh 🤣
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-19-2022, 12:43 PM   #57
wickedred
LOL. To many expensive hobbies between me and my two boys. In the process of an aluminum head 383 swap in my 1984 K5 Blazer daily driver. you know, sense 93 octane gas is $5 a gallon.
Old 06-20-2022, 08:39 AM   #58
SCOTI
SCOTI's Avatar
I hear ya. Crazy thing is try to find a performance based 'built' motor that can live on the cheap swill. I've been seeking combo's that would live on 87 but still make good power. Larger stroked displacement to offset the lower compression. It's been harder than I thought finding something.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-20-2022, 08:40 AM   #59
Joyridin
That is why I went with this LT engine. 11.5 CR on pump 89 octane. Can't beat that and with a 6 speed auto, it should get some decent mileage.
Old 06-20-2022, 08:44 AM   #60
SCOTI
SCOTI's Avatar
I should have mentioned 'on a budget'. Swapping to the newest GEN GM motors is a wise choice if one is prepared for the level of investment. I can't swing that coin & imagine there are many others in the boat w/me.
I was reading some details on them & they are technologically impressive.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-20-2022, 08:48 AM   #61
Joyridin
You will have $6k in a used engine if you install it yourself. That would include headers, driveshaft, engine, trans, and wiring modification. Not really a bad deal when you consider what a rebuilt engine would cost. You can pick the L83 up for under $4k with pretty low mileage. The one I found had 30k for $3500 with trans.
Old 06-20-2022, 10:28 AM   #62
SCOTI
SCOTI's Avatar
I've seen them & 100% agree they're the way to go if you're jumping in the technology end of the pool.
I dont care fot the 6/8speed transmissions. I like to be able to manually shift when desired & don't care for paddle shift options. I'm wading in the kiddie pool
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-21-2022, 07:23 AM   #63
Joyridin
I do not have paddle shift. It is literally a 3 way toggle switch that returns to center. I have to come up with something better, but I rarely upshift or downshift manually anyhow.
Old 06-22-2022, 07:01 AM   #64
wickedred
Truck looks awesome Bro. I'd love to find an LT engine trans setup for $3500'ish. I'd go that way in a heartbeat at this point.
Old 06-23-2022, 07:18 AM   #65
Joyridin
It is an L83 and they are not super hard to find for that price range. The L86 (6.2l) jumps the price about $2-3k. Throw in a cam, headers, lifters, do a tune and you have a bit over 450 hp. Add an intake and you are over 500. Not bad for a little 5.3 liter.
Old 06-24-2022, 06:12 PM   #66
The Rocknrod
Moderator
The Rocknrod's Avatar
I'm still getting 16mpg on mine.
Old 06-24-2022, 08:05 PM   #67
SCOTI
SCOTI's Avatar
Brother..... You don't have to sell me on an OG SBC!
While not as efficient, it can do well enough that it doesn't matter.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-27-2022, 06:46 AM   #68
wickedred
Buddy of mine that I do some turbo fab work for gave me a L83 5.3L. needs some work and I am gonna go through it anyway. So the C10 engine is taken care of.
