06-07-2022, 04:57 PM | #876 |
low n' slo
Re: Project 67 DRGNWGN - 67 Burban!!
heres a cool pcm mount i found on ebay..also my home made ground straps. bought a roll on amazon and some size 12 terminals from autozone and pulled the plastic off. threw a little heat shrink after crimping. think they look nice...
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
06-07-2022, 09:14 PM | #877 |
PROJECT 7DEUCE
Great to see you still plugging along I'm back here for motivation to finish mine.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-07-2022, 10:10 PM | #878 |
Nice progress. Those grounds came out looking good. At least lack of good grounds will be checked off on the troubleshooting list if there’s an issue.
06-10-2022, 06:03 PM | #879 | ||
low n' slo
i had some time today after work before we head out of town for the weekend. got the obd2 port extended and wired in. mine was a 5 wire plug. purple, green, 2 black, and an orange. i tied the blacks in together, cut the purple (was pin 14), and ran pin 2 (green) to the data wire in the pcm (purple wire). and of course orange to 12v constant. also got the pedal plug extended and pluged to the tac module which will also go under the hood. the random wires hanging through the dash is the tach wire, check engine light wires, tcc wire for the brake switch, and the vss wire for the speedo
06-10-2022, 06:10 PM | #880 |
low n' slo
i bought some generic grommets off amazon and ran the wires through the existing holes in the firewall, this way i will only have to drill one big hole for the engine compartment wires from the main harness that is getting wired next week. also a couple of pics of my little harness plugs i made. one goes from the engine harness into the dash for the obd2 wires and dash wires. the other loom in the background is the pedal wire going from the tac to the pedal inside. last couple of pics is the ground block i made for the back. frame to ground block. body to ground block. and so far fuel pump grounded. when its time for the taillights, the last 2 suds will be for those.
06-24-2022, 03:20 PM | #881 | |
BlahBlahBlah
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
06-25-2022, 10:40 PM | #882 |
I resemble that remark. I do a lot of looking without saying a word. I make progress without making a comment also.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
07-02-2022, 09:29 PM | #883 |
low n' slo
lol, well you guys keep peeking in. i been working on wiring lately, i have a thread over in the electrical section for guidance and for the pros to chime in to make sure im doing it right! hate wiring but im getting a MUCH better understanding of how this stuff works. so far i have the rear wired up (tail lights, reverse lights, grounds), wiper switch, headlight switch, cig lighter, and brake switch done. heading to the beach tomorrow so hopefully on the monday the 4th ill be back at it. looking to get the fuel pump harness done and start tackling my guage cluster...not looking forward to that at all
07-21-2022, 07:01 PM | #884 |
low n' slo
little progress but i got my column back from being rebuilt by Les (70shortfleet). looks amazing! got a few things wired and made a power panel under the dash. the left power strip is wired for 12 volt power. middle 2 post is for battery power. right strip is grounds. just in case i want to add some things, i have an easy spot to tap in. also got my LMC dash pad in...fits great, bought it 10 years ago and has been on my shelf the entire time. i know, im random as hell. im waiting on a harness adapter to come in to get the column wired up. its getting there.
oh! also im getting my cluster together. i went with the s10 speedo mod, camaro tach mod, and mid 80s clock. also the ammeter gauge is actually a battery gauge. still some work to do on it, but its coming along.
07-21-2022, 09:06 PM | #885 |
Cluster looks good. I’ll have to check out the s10 mod. I had not heard of that one yet.
07-21-2022, 10:35 PM | #886 |
low n' slo
ya..lot of work but a good alternative to keeping a stock looking dash if using an electric speedo
http://67-72chevytrucks.com/vboard/s...d.php?t=512751
07-21-2022, 10:54 PM | #887 |
The Older Generation
Progress!!! If you do a little each day you will be done before you know it.... I like that electrical setup. LockDoc .
08-08-2022, 10:32 PM | #888 |
low n' slo
been working on getting the inner fenders done so i can get the front wired up. bought some trailer fenders, cut to fit and welded them to a strip of plate. they do bolt in so its easy to take out. still need to seam seal the welds and sand and paint them but you get the idea
08-25-2022, 01:47 AM | #889 |
Nice work! Inner fenders and the tach look great.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
08-28-2022, 07:13 PM | #890 |
low n' slo
so, got the inner fenders painted and back in..got the whole front wiring loomed and routed. had a few wiring issues with the fuel pump and engine fuse block but i think i got that fixed. spent the weekend getting all that wrapped up and fiding a mounting solution to hold the intake stead without flopping around
08-28-2022, 07:14 PM | #891 |
low n' slo
ive owned this truck for 13 years now trying to get it going..and it might not seem like much...but this is the first time i have ever seen the headlights work!
08-28-2022, 09:05 PM | #892 | |
.. .. Sorry, That made me chuckle. You are getting close now. Keep pluggin' away at it. LockDoc
08-28-2022, 09:46 PM | #893 |
08-30-2022, 10:23 PM | #894 |
Dang you are making some great progress!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
08-31-2022, 01:55 PM | #895 |
low n' slo
thanks fellas. I try to work on it every day. I got the lokar shift rod in today, went pretty easy other than a slight bend I had to add to the rod. shifts up and down smooth, and everything lines up perfect except when you get to other D gears. I won't use those anyways so I don't care.
hoping to get some fluids in it soon, bleed the brakes, and maybe add some gas and fire it up to see how she goes.
10-29-2022, 02:38 PM | #896 |
low n' slo
little bit of progress lately. still havent had a chance to fire it up since i have been making the floor in the back. cant weld with gas in the tank
i did start getting together the bag stuff again. im not putting the electric valves back in, going with manual this time. also picked up a viair dual pack off the board here...and got a new tank too! will start getting the fittings together and air line and hopefully start running them. built a little drop box area in the floor frame. was hoping to build an under floor cooler, but instead i will mount the compressors in it. i like to hop around a lot
10-29-2022, 08:25 PM | #897 | |
A lot of custom work. That takes more time, but you are making good progress on it. LockDoc
11-06-2022, 03:13 PM | #898 |
Burb’s looking good!
11-07-2022, 06:15 PM | #899 |
low n' slo
heyo! thanks yall! been busy with a baby shower for my daughter but had a couple hours over the weekend. made a little wooden box to mount my compressors to keep crap away away from them. i got all my fittings in over the week and i think i will start mounting some of the floor to get the tank in and all the air lines in!
11-07-2022, 06:18 PM | #900 |
low n' slo
i stained it a walnut and used a crappy spray clear. will probably go with the same stain for the 2x6 floor but use an actual wood clear coat
