Old 02-06-2013, 07:35 PM   #1
AirSpeed
AirSpeed's Avatar
Turns further left than right
My 72 GMC 4X4 has a 4" lift from the previous owner, they set it up to turn way more to the left than the right. It's a pain in a tight parking lot. I'm pretty sure I need to simply adjust the drag link but was curious if I should set it up to turn equaly in each direction or are they supposed to turn more in one direction?
AirSpeed is offline   Reply With Quote
Old 02-06-2013, 07:57 PM   #2
LONGHAIR
Re: Turns further left than right
It should be basically equal. When the steering wheel is "centered"there will be the same amount of turns in each direction. As far as practical application, you will find that in most street driving, you turn sharper to the right. A left hand turn crosses another lane, making a wider turn.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-06-2013, 08:15 PM   #3
kwmech
Sounds like you need to adjust (lengthen) the drag link. Is the steering wheel straight going down the road?
Old 02-06-2013, 08:18 PM   #4
AirSpeed
AirSpeed's Avatar
It's straight because I mounted it straight. It definately turns left far tighter than right. I'm sure once I get it turning equaly I will have to pull the steering wheel and set it straight again
Old 02-07-2013, 01:19 PM   #5
kwmech
Turn steering wheel all the way in one direction. Turn it the completely the other way counting the turns as you go. Now center the box going back again 1/2 the amount of turns. This will be where the steering wheel needs to be put back on straight. Drive down the road to see where the steering wheel sits while driving straight, make some sort of reference. Turn drag link...lengthening...until steering wheel is where it is supposed to be. Test drive again
Old 02-07-2013, 09:09 PM   #6
Duster
Duster's Avatar
I bet it has a bunch of bump steer too. kwmech is right. drag link. I'm not sure how a 72 is set up but on a 73-87 if you don't have a drop pitman arm, or a stepped drag link, the truck will do just the opposite of yours. If your drag link is at an angle, it will cause the truck not to turn one way or the other. You can articulate a 73-87 to a point where it won't turn at all. That is why people put cross over steering on them.
Duster is offline   Reply With Quote
Old 02-07-2013, 09:28 PM   #7
AirSpeed
AirSpeed's Avatar
No bump steer, it also has a drop pitman arm. I replace all the tie rod ends so I'm going to just buy a new drag link so everything is new, I'll make it a little longer before I install it.
Old 02-07-2013, 09:57 PM   #8
Duster
Duster's Avatar
Hmmm, have you taken it to a good alingment shop? It could be miss alinged. Or there is something wrong with the steering gear box. I not to sure now.
Old 02-07-2013, 10:02 PM   #9
AirSpeed
AirSpeed's Avatar
The steering is fine, I just wanted to make sure if the steering should be equal or turn further one way before I adjusted the drag link. From what I read here it appears it should turn equally each direction.
Old 02-07-2013, 10:15 PM   #10
67swb72klb
67swb72klb's Avatar
good to know mine needs some adjustment also not too bad but noticible when parking
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 02-07-2013, 10:22 PM   #11
AirSpeed
AirSpeed's Avatar
Yea, mine turns to the right about 1/4 of what it does left! I've had to make lots of embarrassing 32 point turns getting out of parking lots. Once I had to wait about 30 minutes for another car to move before I could get out of a space! It sucks!
Old 02-10-2013, 03:44 PM   #12
Mr. 250r
Mr. 250r's Avatar
this is extremely common in old lifted chevys lol i think every single one i have ever been in has this problem surprisingly my suburban didn't have that problem but when i put in a d60 i lost a bunch of turning which is upsetting because before it was pretty good
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 02-10-2013, 05:36 PM   #13
AirSpeed
AirSpeed's Avatar
Right now I can make a u turn left in almost one lane, I'll miss that when I get it adjusted! It will certainly be less embarrassing trying to get out of a parking lot once I get it to turn right! Seems like there's always someone watching me make 35 point turns and they're usually sitting in some stupid little hybrid, disgusted by my big, loud, polluting, gas chugging truck! I try to aim the exhaust at them just so they can suck some fumes, then I do a burnout to burn some more gas and really make them disgusted!
Old 07-08-2014, 09:32 PM   #14
SteveMiller
SteveMiller's Avatar
Guys.
Just learned that the probable cause is your pitman arm is installed to the wrong splines on the steering box.
SteveMiller is offline   Reply With Quote
Old 07-09-2014, 07:10 AM   #15
argonaut
argonaut's Avatar
That shouldn't be possible if unless the output shaft and pitman arm have been modified. Simply lengthen the drag link. Should take about 30 minutes to get it close to centered.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 07-09-2014, 05:30 PM   #16
Bigdav160
Bigdav160's Avatar
I had the same problem as the OP's truck. I had to center the box, then adjust the stops (on the knuckles) to center the linkage. Than I was able to set the toe and center the steering wheel.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-10-2014, 12:58 AM   #17
kwmech
Glad this came back after a year and a half
Old 07-24-2014, 07:24 PM   #18
GuyO
GuyO's Avatar
I think BigDav is right. I had to first disconnect the pitman arm, and center the drag link, center the box then reconnect the pitman arm.
GuyO is offline   Reply With Quote
