Old 04-21-2021, 07:12 PM   #1
Ryanz
Shortbed Wood Floor package? Anyone?
Hey guys - having trouble nailing down a short box wood bed floor kit for my 71 GMC Fenderside 4x4. The vendors in Canada are telling me its special order and could take months.
Would anyone here know of where I could locate one that is in stock, and who is the best to go through? GMC Paul's?
Ryanz is offline   Reply With Quote
Old 04-21-2021, 07:55 PM   #2
67C10Step
67C10Step's Avatar
Re: Shortbed Wood Floor package? Anyone?
https://www.mar-k.com/partList.aspx
Just got my shortbed stepside kit from Mar K in Oklahoma City a few months ago. Picked up my complete bed last month. Give them a call or drop them an email.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is online now   Reply With Quote
Old 04-21-2021, 08:31 PM   #3
tigerburns
Active Member
tigerburns's Avatar
https://bedwood.com/
https://www.mar-k.com/index.aspx
Both of these have similar, American made products. Actually prefer Mar-K a little more myself.
"If you don't do it right, you get to do it again - It's called practice."
"Do you want it right now? Or do you want it right later?"
"Nine women can't have a baby in a month."
"The best ability is availability."
1965 Chevy C10, Short Fleet, 350 SBC - "Sue C (the Banshee)"
1970 GMC C2500 "Longhorn", 400 BBC - "Montana"
tigerburns is offline   Reply With Quote
Old 04-21-2021, 08:58 PM   #4
Ryanz
Excellent! Thanks guys
Old 04-21-2021, 09:01 PM   #5
Grumpy old man
Grumpy old man's Avatar
With the cost of shipping you may find it easier, faster and less expensive to have a local cabinet shop in your area cut the boards for you . Here are the dimensions .
https://www.mar-k.com/PDFs/Instructi...Dimensions.pdf
Old 04-21-2021, 10:21 PM   #6
Ryanz
I had thought about that but wasn’t sure about proper grooves and oblong holes for bolts. Not to mention proper bolts. Have others done it this way and had success?
Old 04-21-2021, 10:25 PM   #7
Carl Spangler
Carl Spangler's Avatar
Put this "diy chevy wood bed" in the YouTube search box. There are several DIY build vids.
1971 SWB step side: Original NM Forestry and then NM Fire truck
Carl Spangler is offline   Reply With Quote
Old 04-21-2021, 10:41 PM   #8
Ryanz
Will do - thanks Carl. Appreciate it.
Old 04-21-2021, 11:37 PM   #9
StingRay
StingRay's Avatar
I got the dimensions off of GMC Pauls site
https://gmcpauls.com/47-72_BedWood_Info.htm
I'll make mine out of hardwood. Likely maple. I've already modelled it up in 3D cad.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 04-21-2021, 11:44 PM   #10
Ryanz
Why am I not surprised
Old 04-22-2021, 03:16 AM   #11
franken
Not surprised by? Just curious...
If the plan is to paint the wood like GM did, yellow pine will work and is pretty tough. Or hardwood if preferred.
I'll bet the local home store can use their panel saw to rip planks to the proper width.
A router and careful use of a clamped fence could be used to make the grooves.
Stainless carriage bolts are readily available.
Seriously, a naturally wood be can get new wood for not a ton of money, but yes a bit of labor. Converting from one bed floor to another is a bit more involved to say the least.
Old 04-22-2021, 09:40 AM   #12
StingRay
StingRay's Avatar
Here's my cad model.
Canada
Old 04-22-2021, 10:27 AM   #13
Ryanz
I meant you're so damn detailed and smart with all of this stuff - 'I'm not surprised you spec'd one up'. Brilliant.
Old 04-22-2021, 10:30 AM   #14
StingRay
StingRay's Avatar
Your step side bed is the smallest and simplest to build. You could do that up with little more than a table saw with a dado blade, a drill press and maybe a router. Having access to a planer would be handy if you don't or can't start with finish sized lumber.
Canada
Old 04-22-2021, 11:20 AM   #15
dagnabbitt
dagnabbitt's Avatar
I intend to cut my own bedwood too, I have been collecting the woodworking tools I need and will make it according to the spec Grumpy posted. I am looking forward to it because I am a much better carpenter than a mechanic!
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 04-22-2021, 11:57 AM   #16
hevy_chevy67
hevy_chevy67's Avatar
Never used them but I see this guy is just outside of Saskatoon.
https://www.hindsightbedwood.ca/
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e
1970 Chevrolet K5 Blazer - Project
1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4
1969 GMC Suburban - 5.3 LS, 4L60e
hevy_chevy67 is offline   Reply With Quote
Old 04-22-2021, 12:05 PM   #17
Stover93
I got mine from classic parts in KC (local to me). The premium oak looks great and they mill it in their own shop on-site. Shipping to Canada would be pricey though I'm sure.
Stover93 is offline   Reply With Quote
Old 04-22-2021, 12:22 PM   #18
Ryanz
Hey this is AWESOME!!! I've left him a message. Thanks a ton.
Old 04-22-2021, 04:25 PM   #19
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Did mine at a local wood shop using the measurements on GMC Paul's site. Took a few hours and ended up costing much less than the kits. I used a hard maple.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 04-22-2021, 04:39 PM   #20
LS short box
Per the box pictured above I clearenced the bottom of the bed wood for the head of the cairridge bolts so I didn't have to drill thru the bed wood the hold the box down.
Old 04-22-2021, 10:33 PM   #21
Ekliptix
Ekliptix's Avatar
Thanks for this recommendation! Love to buy Canadian when possible.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline   Reply With Quote
Old 04-23-2021, 08:05 AM   #22
67C10Step
67C10Step's Avatar
Ekliptix,
As crazy as it may sound coming from a hillbilly way down in Arkansas, a significant part of my family is from the Lethbridge/Calgary area in Alberta. My grandmother was born and raised in your area.
Some really nice work in this thread. If I still had access to a woodworking shop like my grandfather had when I was growing up I would have made my own as well. Probably from black walnut as that was his preferred wood for everything he made.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
Old 04-23-2021, 09:41 AM   #23
Woodnears
Surely someone makes a router bit for the groove profile... I used to build commercial grade cabinetry for many years and from time to time we would build things like this that we had to get custom ground router bits, wish i could remember who did them for us!
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417
Woodnears is offline   Reply With Quote
Old 04-23-2021, 10:01 AM   #24
old51sedan
old51sedan's Avatar
One of my buddies from high school has a farm, cuts his own wood and had a bunch of oak 4/4 been drying in his barn for years. We plained it down to 3/4, cut it to size, followed plans posted on this site and did the floor for my truck two years ago. I eliminated the bolts thru the floor by welding ones onto the cross members. Have a rear tank, installed the gas fill on inside of box for a cleaner look.
old51sedan is offline   Reply With Quote
