01-02-2015, 05:00 PM | #1 | |
Re: 68 c10 2wd in Sacramento, CA
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
01-02-2015, 05:29 PM | #2 |
Thanks, that is what I wanted to hear. His 68 already has power steering so I will do as you and just transfer everything but the box.
I am also assuming we will need to use the newer master cylinder and booster as the old MC was set up for drum/drum. Thanks again.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
01-05-2015, 12:20 PM | #3 | |
01-06-2015, 04:18 AM | #4 |
Thanks again. While my son is finishing the body work, I am going to get the suspension swapped over (much easier with the body off). Unfortunately, the parts truck (78 C10) we bought cheap a friend really wants to build up, so he is going to look for just a suspension set-up for us to swap for the parts truck.
