11-23-2020, 08:13 AM | #1 |
Active Member
67 Panel side windows?
I have a 67 Panel , it has small side windows, I figured they were added by a owner but I just see one on youtube that a guy is building. No options for it, anyone post about this before?
11-23-2020, 08:22 AM | #2 |
Re: 67 Panel side windows?
Side Windows were not available from GM, hence the name, Panel truck.
Most were cut for parkway use, at least in the states were those laws are applied. |
11-23-2020, 08:30 AM | #3 |
Active Member
I know it's a panel, but the windows look factory and it's not the only one I've seen
11-23-2020, 09:08 AM | #4 |
It's definitely not factory. My comment wasn't to belittle your intelligence either about what a panel truck is, these were business billboards back when they were used as work trucks.
11-23-2020, 11:39 AM | #5 |
The Older Generation
I agree with the others. Not available from the factory. There are some skilled bodymen out there and it would not be a problem for them to install something like that and make it look factory. I have seen pictures of other Panel Trucks with windows like that too, Full side windows also. LockDoc
12-08-2020, 07:22 PM | #6 |
Active Member
Got this from a customer today.
01-16-2021, 10:57 PM | #7 |
How did I get this OLD!
My 67 panel has them too. Professionally done but not factory. 2 on each side
Michael http://67-72chevytrucks.com/vboard/a...1&d=1610852144
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
01-17-2021, 12:57 PM | #8 |
BlahBlahBlah
Could be a neat custom cluster. Like the panel side windows though, clocks were never a stock option in our trucks.
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
01-18-2021, 08:45 AM | #9 |
low n' slo
i wonder what clock that is? looks like it matches pretty good with the stock gauges
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
08-30-2021, 07:10 PM | #10 |
Active Member
I don't what clock it is , I have removed the side windows and getting ready to weld In the patch panels.
