11-23-2009, 10:05 AM | #1 |
BBC Help!
I am considering freshening up my 402 and I ran across a great deal on a NEW 2000 L-29 Vortec long-block crate engine. With a shipment from Summit and some assembly work, I could have a new 4-bolt-main, roller-cam 454 ready to drop in for less than $2,300. If I have my 402 rebuilt, I fear I would have to spend close to that for the disassembly, hot-tank, machine-work, bearings, cam, reworked heads, assembly, etc.
Do I store my 402 and install/drive the 454 or freshen up the 402 and not worry about having to store the original engine? Am I missing any good alternatives here? |
11-23-2009, 12:10 PM | #2 |
Re: BBC Help!
I would personally want to keep the original engine with the truck
11-23-2009, 12:12 PM | #3 |
Re: BBC Help!
I would go 454. Save the 402 in case you want to sell the truck someday. A big block truck with the original engine is probably worth something to someone. Unfortunately a fully loaded big block truck is just not worth what a similar equipped car is worth. If you want to drive it, you will like the 454 WAY more than the 402.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
11-23-2009, 12:14 PM | #4 | |
Re: BBC Help!
Agreed!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
11-23-2009, 12:15 PM | #5 |
The Older Generation
Re: BBC Help!
I am thinking about replacing the engine in my '70 Chevy slide in camper truck with a crate engine. If I do I will keep the original 350 in case a new owner might want to rebuild it. It does run but definately needs rebuilt. LockDoc
