Old 03-19-2002, 04:20 PM   #1
dubie
dubie's Avatar
Post Anyone have install instruction for a floor shift kit?
It's a 3 speed column shift, that I am changing to floor shift. I have a Mr.Shift M5 kit made by Sparkomatic. Anyone have the instructions or know where I can get them?
72 C/10 LWB 2wd
250 inline 6, 3 speed column shift. Soon to have a total facelift.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-21-2002, 10:27 AM   #2
dubie
dubie's Avatar
Post
anyone??
72 C/10 LWB 2wd
Old 03-21-2002, 11:43 AM   #3
69 longhorn
Post
Im not familiar with that one,but the old Hurst shifters had a plate that bolted to the side of the trans,& a brace that ran to the top corner on the other side. If the handle is removeable,you can get the shifter pretty well in position,then mark the hole from the bottom. Once the hole is marked,I would drill holes in the corners ,from the bottom,& then go topside with a jig saw to cut the opening. There are oversized boots if you miss the hole by a little(been there,done that!). after you get the shifter mounted,chok the wheels& put the trans in nuetral to adjust the linkage. There should be holes in the shifter arms to slide a 3/16 or 1/4" pin through to line up the nuetral position on the shifter. Once that is pinned, & the arms on the trans are in neutral,the lenghts of the rods are adjusted . hope that helps.......69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
