Old 03-21-2002, 12:10 PM   #1
Fast68Chevy
Fast68Chevy's Avatar
Post uhmm temp gauge haunted.. hmm..
ok does anyoen got any idea why a temp gauge needle would peg past 220 and jam there during engine cranking ?
if i physically unjam the needle after engine fires up then it falls below 220 where its supposed to be and is fine after that, until i shut off engine and fire it up again.. if wire was grounded or sender was bad then it would stay pegged, so...
hmm... wierd...
anyone ?
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28(Z28) 1G1AP87GXEL100000 with H.O. 305/4bbl/190net/hp(L69) 3.73 rear(GT4/YC4) 700R4(MD8-MXO) & other goodies
-79 G20 pass van, 350/th350/10bolt,
paint is overrated
Randy- Lincoln, IL
randy@ccaonline.com
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 03-21-2002, 12:16 PM   #2
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
Lightbulb
Fast, I'd say you have a short. Possibly a bad ground. This happened to me a year or os ago and the sender was fine. The reason I believe, I just washed the engine bay and must have knocked the wire a little. I put a ground wire on my clutch housing from my battery. Then put a wire inside the cab from clutch housing to temp harness. Works fine now.
67 Chevrolet LWB with rebuilt 292. 415 ft. lbs of torque, 4 speed, 3.73 Posi, straight and almost painted.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 03-21-2002, 12:31 PM   #3
Fast68Chevy
Post
the gauge runs off of variable ground though.. IE the dk greeen wire..
the gause recieves hot feed all the time when ign is on
not sure how bad ground would affect it and not anything else in the panel.. so,
hmm.,
thanks
[This message has been edited by Fast68Chevy (edited March 21, 2002).]
