04-06-2002, 09:59 AM | #1 |
Will 2000 GM wheels fit 67-72 6 lug pattern??
Gentlemen-
Will the more modern...say 2000 6 lug GM truck wheels fit on our 67-72 six lug trucks. I measured mine at a 5.5 pattern. Up to what year will bolt up?? Any that I should stay clear of?? Thanks. ------------------ 67 Chevy C20 LB Stepside, 350 4-bolt with goodies.
'94 GMC Seirra Ext. Cab '67 Formula Firebird '89 GSX-R 750 |
04-06-2002, 10:25 AM | #2 |
I am a Referee of life.
Blacksheep,I beleive this question was asked but if I remember right the center spindle hole is smaller on the later wheels.You might want to check before you drop the $$$ for wheels.
------------------ Deland does Chevys 68Chevy panel(LIZ) "A man and his truck,it's a beautiful thing" "I have the body of a god,unfortunately it's Budda"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-06-2002, 10:47 AM | #3 |
Recovering Truck Driver
I have a friend who tried to put oem wheels off a 93 onto his 76 4X4, the centers of the wheels were too small to fit over his hubs.
------------------ '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84 ralleys and 31/10.5s 67 Cutlass convertible 330, 3spd stick 90 GMC Jimmy 350/auto Chad Stephens Orleans,NE
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
04-06-2002, 12:33 PM | #4 |
I put a set of 97 rally rims on my 69 C-30 frame. Had to replace all of the studs with 14mm after that they fit perfect.
------------------ 72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans 3" Exhaust W/Headers C30 Frame C10 Suspension Short Wheel Base (Dually)
72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans C30 Frame C10 Suspension Short Wheel Base (Dually) |
04-06-2002, 01:20 PM | #5 |
Collector of rusty Items
Just don't try to use any late model Ford wheels, they are metric. Another one of Ford's better Ideas, screw up the system that has been in place for 40 years.
------------------ Scrub 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
04-06-2002, 02:36 PM | #6 |
Member since 2000
i have seen a our trucks with 2000 wheels on them, the center hole thing is huge compare to our trucks. they stick in thw wheel well so dont look to great.
------------------ Mechanic @ California Concept Britney: 1970 2wd K/5 Blazer (Frame up) Jessica: 1967 2wd SWB (pops daily driver) Helga: 1972 4x4 3/4ton LWB (my daily driver) AIM:Alexmart1 Mountain View, Cali |
04-06-2002, 08:05 PM | #7 |
Thank you-
I was looking at a set on e-bay, but sounds as though I better hold off or buy new six lug rims from Jegs. So much for saving a buck, huh? ------------------ 67 Chevy C20 LB Stepside, 350 4-bolt with goodies.
04-07-2002, 01:35 AM | #8 |
I tried '98 Tahoe ralleye rims -- perfect fit
just heavy as heck. |
04-07-2002, 03:59 AM | #9 |
Actually the 6 lug wheels off the 1999 and up Chev Silv./GMC Sierra's will not work 67 - 72 6 lug trucks because of the center hole is too small, but w/ a modification of the of hole, then it will fit on to the Hub, but other then just modifying the hole on the wheel itself, the bolt pattern is the Same!! I know, my dad was given an extra set of Wheels off of his neighbors 2000 Silverado, and I tried to put them onto my 68 Chev and my hubs were too large!!
------------------ Truck #1 68 Chev LWB Fleet w/ Wood Floor (Sucks Gas and Hauls Ass!) and in process of Body Work... Truck #2 1994 GMC Sierra SL w/ 4.3L Vortec V6, 4L60E Auto!!
1968 C10 Truck LWB Fleetside 1968 C10 Truck SWB Stepside 1994 K2500 Ext Cab Fleetside 2008 Honda Civic Si *lease* |
04-07-2002, 06:28 AM | #10 |
The bolt pattern is 6 on 5 1/2, just like all GM 6 lugs, but any '88 and up truck wheel has 5 1/2" backspacing instead of the 3 1/2" that was used until '87, including the '67 - '72 era. This will move the tires 2 inches farther into the wheel wells. Would not look good, imo.
------------------ Tim
Tim |
02-04-2015, 03:44 PM | #11 |
Re: Will 2000 GM wheels fit 67-72 6 lug pattern??
Can't I get around the larger hub on my 68 and the backspacing issue by installing a 2" wheel spacer? what are your thoughts?
02-04-2015, 03:55 PM | #12 |
any one know of a way to widen the center holes on newer chevy 6 lug wheels? other than a lathe i mean. like a way we can modify using home power or hand tools?
1967custom |
02-04-2015, 05:30 PM | #13 |
My opinion?
The backspacing issue is the killer for me. My thought is, if you have to run an adapter or a spacer for a wheel to work, it's not the right wheel for the vehicle.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
02-04-2015, 07:28 PM | #14 |
Times 2!
HSRACER Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
01-05-2016, 02:15 AM | #15 |
The newer trucks..88 and up have a different off set and back spacing..and the diameter of the center is smaller..on a 67-72 the wheels will sit way in the wheel well so it's not worth Maki g the hole bigger for an ugly look..
01-05-2016, 10:21 PM | #16 |
The wheel offset from new rims to old spindles will allow them to fit with custom spacers, which will also fix the hub bore issue. I had a set made from motorsport-tech.com. I am doing the same thing. They are a bit pricey at $285 though.
01-05-2016, 10:28 PM | #17 |
You can check here, http://adaptitusa.com/6-lugto6-lugadapters.aspx
Terry Soon to be retired and moving to Bristol, TN. |
01-06-2016, 05:24 PM | #18 |
I like the looks of the 2000 chevy truck wheel. I am converting to disk brakes on front of my 70 C10 by installation of a later model 'K' member and was thinking like 67blacksheep.
I am adding a conversion rotor to keep 6 lug up front. Does anyone know of an aftermarket cast wheel that looks like the 2000? Thanks |
01-06-2016, 06:53 PM | #19 |
67blacksheep I know the wheels you are looking at might be different from these, but to get these to fit we bought 6 lug wheel spacers found here
http://www.ebay.com/itm/6x139-7-to-6...-/181035692411 might not be the right ones for you, just need to measure them. they bolt on to your existing lug nuts then we just bought 2000 Tahoe lug nuts to screw on the center caps |
01-06-2016, 06:54 PM | #20 |
we also have drop spindles and front disk brake conversion
01-06-2016, 07:43 PM | #21 |
and you wanna know what i found out the hard way????? you cannot use older 15 steel wheels like rallys on the newer 6 lug pattern!!! the calipers hit the rim!!
1967custom |
01-08-2016, 03:23 AM | #22 | |
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
