Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 11-28-2004, 09:13 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Tailgate support cable installation instructions
Here are the instructions that several members requested I post describing the conversion from metal tailgate support straps to cables. The pictures may not be in order but hopefully they still make sense. It will take two posts for all the pictures.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline
Old 11-28-2004, 09:18 PM   #2
mocwon
Keep On Truckin'
mocwon's Avatar
More...
More pictures
Just Passin' Thru
mocwon is offline
Old 05-18-2006, 08:33 AM   #3
pat
pat's Avatar
Re: Tailgate support cable installation instructions
Ive got some recent pictures that might help some people out. I found the perfect bolts to use instead of grinding them down, they arent grade 8 or anything, but I think they should work. They are the bolts used for leveling cabinets and things, worked great. They have a very low profile head.
You can see in this pic where you have to grind on the tailgate to clear the cable.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
Last edited by pat; 01-30-2007 at 01:58 PM. Reason: cant post replies to the FAQ anymore?
pat is offline
Closed Thread
