What do you think is the smallest tires and wheels i should put on a truck with a 4"-6" suspension lift?
------------------ 94' 4X4 GMC Sierra
94' 4X4 GMC Sierra |
Strongman Garage
![]() Join Date: Apr 2000
i thought the point of lifting was to put big tires on?
well id say 33s would be the smallest ------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
I agree.. 33's with a 4 inch is ideal. 35's to 38 with the 6 inch lift. But also keep in mind your tranny gear ratio and axle ratio. Just make sure the motor rpm's are within the engine torque range. This will help save gas and wear and tear on the drivetrain.
Good luck.. Rock on people!!! ------------------ 74 Chevy K-5 Blazer. 565 Tall Deck Big Block Chevy, 4.5 bore, 4.50 stroked crank, 10 to 1 pistons that are 60 over, aluminum heads with full rocker cam and lifters. hooker heads with 1 7/8" primary and 4" collectors to a pair of flowmasters. 4spd auto, 205 T-case, Dana 60 front limited slip, Corp 14 bolt rear lockers, with 4:88. Working on a 4 link coil over spring front suspenion with 63inch leaf link rear suspenion. Running 38 Ground Hawg tires on custom 16.5 bead locked rims. 8 point roll cage and lots of other goodies. Its my money pit land boat, but I love it!!
I'm the third owner of this 74 Chevy K-5 Blazer mostly stock back in the day. Since the start of the build up the truck now has a 540 Tall Deck Big Block Chevy, 4.5 bore, speed-o-motive 4.25 stroked crank, 10 to 1 pistons that are 60 over, 800 CFM performer carb on a 454-0 aluminum intake, Brodix 2X aluminum heads with full rocker cam and 7:1 lifters. hooker heads with 2" primary and 4" collectors to a pair of flowmasters. A preped 700R4 rated to 700HP, 205 T-case, Dana 60 front limited slip, Corp 14 bolt rear lockers, with 4:88. Working on a 4 link coil over spring front suspenion with 63inch leaf link rear suspenion. Running 38 Ground Hawg tires on custom 16.5 Trail Ready bead locked rims. Custom dash with Auto meter gauges, Bear custom seats, 8 point roll cage and lots of other goodies. Its my money pit land boat, but I love it!! |
