05-30-2002, 01:40 PM | #1 |
dying plastic door panels from black to blue!?
well i heard some bad stuff about the repro 72 door panels but i found a set of really good black ones, is it possible to spray them with some sort of plastic dye? i want to get them blue? will it hold up or should i not bother and wait for some blue panels. also where can i get the dye?
05-30-2002, 01:52 PM | #2 |
Southern but in Ohio!!!!
It would be up to you but I have done it with old jeep seats it dosnt look to bad, their is a primer to help it stick, & a clear you can put on to make it shiny. I dont know how well it will work going from black to blue. It would be better going from a light color to a dark. you can some times find it at auto zone, I would try Paddock they carry all the interior & vinle dye & it is made to be the same color of origenal colors for our trucks.
Hope this helps you out? Rob. Diggin 69
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79 1972 custom-10 half/ton longbed 1980 1/2 ton 4x4 all original 350/350/205 with air Eaton,Oh rebelryder@hotmail.com |
05-30-2002, 02:01 PM | #3 |
The kid that previously owned my truck, just used some tremclad in a rattle can to paint the panels. Still holding up after 5 years.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
05-30-2002, 05:49 PM | #4 |
I have a set of white one if you want to swap and there is a vinyl called SEMS that I've had alot of luck with, hope this helps.
Things happen for a reason! |
