Old 07-09-2005, 08:16 PM   #1
C30_Dually
1-Ton Dually Owners: anyone go from 16.5" rims to 19.5" ??
To improve the mileage on my 4:10 rear / 454, 1981, 2WD, 1-ton, I am thinking of moving from the stock 16.5" up to 19.5" rims (as used on tow trucks and 3500HD's).
Anyone out there on the forum do this?
If so, what was the mileage result?
What tire size are you using?
Any clearance issues?
thanks.
C30_Dually
C30_Dually is offline   Reply With Quote
Old 07-09-2005, 08:18 PM   #2
C30_Dually
1 more Question.
I forgot to add:
What about RPM difference at highway speeds?
C30_dually
Old 07-09-2005, 11:40 PM   #3
KdawgS10
keller
KdawgS10's Avatar
if your main consern is gas milage. woulnt ti be mutch cheaper to just get bigger tires?
of co4rse 19.5s are cool. but you seem to just want more milege.
83 1ton 4door dually, 350/700r4
99 S10 2.2/5speed bagged. traded for the dually
91 S10, 2.5/5speed juiced
87 3/4 4x4, 350/4speed
89 S10 long bed , 2.8/5speed
65 chevy short bed stepside, 327/3speed
97 neon acr, 2.0 dohc 5speed DD
KdawgS10 is offline   Reply With Quote
Old 07-10-2005, 10:14 AM   #4
C30_Dually
sidewall concern
Taller tires would be a way to go, however, this truck is used primarily for trailering, both a 20ft enclosed from the class3 hitch, and occasionally a 45ft, triple axle 5th wheel. I think taller sidewalls would change the handling of the truck while pulling 4 tons behind me. A scary thought in my book.
The coolness factor is an added benefit of going to the 19.5's.
C30_Dually
Old 07-11-2005, 06:34 PM   #5
GMC1tondually4dr
I own a '86 Dually 2WD 1ton with a 454 and 4:10 gears. (over 200,000 miles on the engine. ...yea...she be TIRED!!)
I get approximately 9-10 mpg unloaded. Approximately 6-7 mpg towing a 15,000 40 foot gooseneck racecar trailer.
Improved mileage will be relative......... ......
If you get 10mpg now, a 25% improvement would get you 12.5mpg...
Don't expect to get 15 plus mpg or more.....it won't happen......
UNLESS you are going down a VERY steep hill and have a strong tailwind......
Look on the Moser rearend site. I think they have a rpm=mph tire size converter.
Taller tires will help.........but not a much as you would expect
...about 2-300 rpm.
A gear change about 5-800rpm.
A GearVendors Overdrive will drop the engine rpm approximately 25 to 28%.
By the way my STOCK size wheels and tires are 16" tires, LT235/85R 16,
Pirrelli Scorpion they are 31" tall. (Got them at Sears for around $95-100 on sale. good price)
Just my .02
CCDually
GMC1tondually4dr is offline   Reply With Quote
Old 07-11-2005, 07:41 PM   #6
KdawgS10
keller
KdawgS10's Avatar
what tranny ya running thier GMC1tondually4dr ?
I havent got to drive my "new to me" 83 4 door dully 2wd and I was wondering what kinda milege I will be seeing with my 350/700r4 4:10s
235-75R16s unloaded ?
Old 07-12-2005, 01:12 AM   #7
GMC1tondually4dr
TH400, a very good trans guy built it for towing. Has an Allison converter,
also for towing.
John, owns Master Transmission, Rosemount, MN. (also a very good guy!)
Measured them tonight, unloaded.
Just my .02
CCDually
Old 07-14-2005, 01:37 AM   #8
86SILVERADO
86SILVERADO's Avatar
HMMM.... Haven't considered the larger rims but I did just step up to 4.10's from 5.14's I figured out it will be about 700 rpm difference.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
