Old 04-16-2002, 02:49 PM   #1
cheyenne10
cheyenne10's Avatar
Post How to remove window tint?
Is there a way to remove the "home-job" type window tinting off of the inside of windows after yrs of baking it on and bubbling, etc.?
Bob
cheyenne10 is offline   Reply With Quote
Old 04-16-2002, 02:57 PM   #2
paintpyro
paintpyro's Avatar
Post
Grab a razor blade and some glass cleaner. Use the the glass cleaner as a lubricant so you dont scratch the glass and start scrapin a corner. You may be able to peel from the corner, but it may leave a film behind that youll need to scrape off. Have fun, I did my rear window in about 15-20 minutes.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 04-16-2002, 02:59 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Post
Razor BladeJust be careful not to scratch the glass. You can get plastic razor blades too but they don't work as well.
'69 K-5 Blazer - 350/TH350, 6" lift, 35" tires
Bothell, WA
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-16-2002, 03:44 PM   #4
j-dogg
Post
I *think* ammonia will loosen the adhesive. That is what the tint shop said they use to remove old tint.
j-dogg is offline   Reply With Quote
Old 04-16-2002, 04:06 PM   #5
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Wink
Get an edge started, and use a blow gun and it will blow it right off in one sheet. I have done this many times, then just clean what glue is left.
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 04-16-2002, 05:07 PM   #6
Shane
Shane's Avatar
Post
once you get the film off, you can use Acetone or Laquer Thinner to clean the remaining glue. The glue is the hardest part of removing tint. Be carefull with the acetone or thinner. Pour some on a rag, wipe the glue, let it sit and soak, pour more on rag, and then wipe. Repeat, repeat, repeat. If you can keep the glue damp, the easier it is to come off, and flip your rag pretty often because it will build up with all of the old glue and if you dont flip it or change it out often, you only put the glue on the rag back on the window.
hope this helps...
Keep On Truckin'
Shane
Athens, Alabama
Shane is offline   Reply With Quote
Old 04-16-2002, 05:28 PM   #7
cheyenne10
cheyenne10's Avatar
Post
Sounds like good advise and fast responses too. Thanks a bunch.
Bob
Old 04-16-2002, 05:35 PM   #8
Maximum Overdrive
December 21, 2012
Thumbs up
Just did this myself yesterday. Went got a razor scraper( handle with replaceable razors) cost 1.53 and just sprayed the window with windex and scraped it right off. Then went back and sprayed alot of windex on the window and scraped the glue off next. Used a new blade for each window. Took me about 10 min each window including wing windows.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 04-16-2002, 08:28 PM   #9
Andy4639
Old member
Andy4639's Avatar
Cool
I did my two side windows about a month ago. I used simple green and the stuff just about came off by it's self. I also used a razor blade. SIMPLE GREEN
Andy
71's Are for ever!!! or 67,68,69,70,72
www.geocities.com/chevy71tpi/main.html]
www.picturetrail.com/Andy4639]
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-16-2002, 08:31 PM   #10
71BBK10
Teufelhunden
71BBK10's Avatar
Post
i used razor blade, blow drier and some brake fluid on a rag to do mine
1971 K10 lwb fleetside 402 T350 205
71BBK10 is offline   Reply With Quote
Old 04-17-2002, 08:26 AM   #11
Smooth68
Smooth68's Avatar
Post
Brake fluid?!?! Yikes....be careful on those painted areas!
Prost68trk web page
or btshaffer@wmconnect.com
'68 short/wide, 402BB/TH400, '81 rear frame rails, F@rd 9" 31 spline, leaf springs moved inboard, shaved firewall, cab seam, wiper cowl, dash, hood ridge, chrome drivetrain.
'97 Z-71 Ext-cab Driver
West Fork, Arkansas
IM - btshaffer (will soon change)
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 04-17-2002, 09:00 AM   #12
Alvin
Never Done?
Alvin's Avatar
Post
I found out a few days ago that starting fluid removes the glue pretty well. Wish this post would've popped up a few days sooner though. Spent a few hours scrapin' on mine
- Adam L. Vogel
White 68 GMC short, fleet, 350/TH350, 67-8 chevy grille, 5-lugs, front power disc brakes, power steering, a/c (not complete yet)
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
