Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 02-20-2006, 11:10 AM   #1
67ChevyRedneck
67ChevyRedneck's Avatar
Cab mount problem.
I replaced the cab mounts on my truck this weekend. It's a real pain if all you have is a hammer and chisel to break the spot weld on the front mounts. The bolts all came out fairly easy after I gave them a good tug with a 1/2 drive ratchet and pipe The back mounts were actually in pretty good shape. The front mounts crumbled when I pulled them out. I did not do this safely, so I will not be describing how I changed them. I did change them one at a time so the cab wouldn't move.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline
Old 02-20-2006, 11:11 AM   #2
67ChevyRedneck
Re: Cab Mount Replacement pics.
Here's the new mounts installed from GMC Pauls. I also cleaned up the frame mounts and painted them with some of Eastwood's rust encapsulator.
Jesse James
Project "On a Dime"
Old 02-20-2006, 11:16 AM   #3
SLIMJIM
Nice work 67. Did you use the spray or the brush on Encapsulator?
SLIMJIM
1970 Chevrolet Blazer 2 wheel drive - SOLD
SLIMJIM is offline
Old 02-20-2006, 12:44 PM   #4
67ChevyRedneck
SLIMJIM
Brush on. I couldn't bring myself to pay that much for something in a spray can... you loose to much to bad aim/overspray/mist etc.. Plus you can thin it 20% with laquer thinner to stretch it a little farther.
Jesse James
Project "On a Dime"
Old 02-20-2006, 01:57 PM   #5
69sixpackbee
Did you replace the radiator support cushions too?
69sixpackbee is offline
Old 02-20-2006, 01:59 PM   #6
matthufham
do you have the bed and fenders on? i found when using the poly ones from gmc pauls i had to use washers to shim up the cab because the mounts were too short.
matthufham is offline
Old 02-20-2006, 02:08 PM   #7
67ChevyRedneck
I plan on replacing the front fenders and doors as well. I have the kit for the radiator, but I won't be messing with it until it's time to install the fenders and doors.
My truck is a stepside, so the bed bodyline/cab alignment isn't important. The front fenders are on as well. Didn't notice and difference in the alignment. I too was a little disappointed that there were no metal washers for the tops of the cab mounts. I cleaned up and used rust encapsulator on the original large washers and put them on top of the mounts, you can see them in the pics.
Jesse James
Project "On a Dime"
Old 02-20-2006, 02:09 PM   #8
JAKES 68GMC
Aluminum slot wheels rule...
Did it mess up your door gaps or bodylines after you put the new bushings in? How was the quality of the bushings?
JAKES 68GMC is offline
Old 02-20-2006, 02:16 PM   #9
67ChevyRedneck
I didn't notice any difference, but I can't exactly say my doors/fenders were aligned well in the first place. I have no idea how to judge the quality of the bushings, this is the first set I've ever physically put my hands on or even seen in person.
Jesse James
Project "On a Dime"
Old 02-20-2006, 02:34 PM   #10
67ChevyRedneck
Originally Posted by JAKES 68GMC
Thanks. Didn't know whether new bushings would affect the way my doors open and shut. (they shut really good)
If your front bushings are as shot as mine were, it is possible you would have to either realign the doors and fenders. I didn't care becuase I'm installing new doors/fenders anyway.
Edit: I would have to add that my front mounts were so shot that the new ones raised the front of my cab at least 1/2"
Jesse James
Project "On a Dime"
Old 02-20-2006, 02:55 PM   #11
shifty
Questionable
shifty's Avatar
Excellent work - and thanks for sharing. I've also got this in my near future, but I'm having to hold off a bit on my spending on the truck because of medical bills
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline
Old 02-20-2006, 03:29 PM   #12
iamthor
iamthor's Avatar
Your bolts came out looking a little better then mine did. Looks good.
Rollin in my 64....GMC Suburban
iamthor is offline
Old 02-20-2006, 03:33 PM   #13
67ChevyRedneck
Yeah, I think you can buy just the bushings, but I can't see how you can reuse the metal parts. My front bolts were salvageable, the back ones were badly pitted. All of the metal sleeves fell apart when I took them out and even some of the washers had some bad pitting. New bushings AND hardware is the only way to go. Your front cab mount looks REALLY squished compared to mine!
Jesse James
Project "On a Dime"
Old 02-20-2006, 07:15 PM   #14
iamthor
iamthor's Avatar
My GMC is slightly older, a 64, and it’s a Suburban. That’s probably why their so flat. Your final product came out real nice. I like the coating.
iamthor is offline
Old 02-20-2006, 11:55 PM   #15
Green Machine
Green Machine's Avatar
Chevy Duty and LMC among others sell mounts that are dupicates of the originals and fit better than those IMHO. Also check the bolt strength, the originals were grade 5 or grade 8 bolts, some kits only have grade 2 bolts, not what I want holding my cab on.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline
Old 02-21-2006, 09:16 AM   #16
67ChevyRedneck
Can't be any worse than the rusted out crap that was on there before the swap Also, if the original front mounts squished that bad I don't want "duplicates of the originals." Thanks for the info though, I'm sure some people would like to use an original style kit.
Jesse James
Project "On a Dime"
Old 03-11-2006, 12:31 PM   #17
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
Question Cab mount problem.
Well I have a 70 c20 and I got the right kit from chevy duty. But the thing is, I dont have any directions. so I dont know where each washer goes or where each bushing goes. If any one has a picture to show what goes where, or if you just know how to do it please explain. Thanks in advance.
1970 GMC C-25 LWB (middle of frame up)
5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood.
1987 Camaro z28
350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer.
1988 Monte Carlo (Super Stock ashpalt race car)
My Truck
DTerry is offline
Old 03-11-2006, 01:14 PM   #18
Solver
Solver's Avatar
Re: Cab mount problem.
here is my info hope it helps
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline
Closed Thread
