Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 04-03-2006, 06:19 PM   #1
ARAMP1
ROCK*STAR
ARAMP1's Avatar
PLEASE HELP With Q-Forms Kick Panels!
I got a set of Q-Forms kick panel replacements and I’m having a bit of trouble with the install.
On the drivers side, the parking brake pedal is WAY too close and hits the speaker. I’ve thought about moving it over about two inches to clear.
On the passenger’s side, there’s the cold air vent. I have a Silverado with the deluxe interior and I figured that I could just use the base model vent because it doesn’t have an attached kick panel. Well, I bought a base model vent and it is just too big. I’m wanting to know how anyone modified the Q-Forms panel or the stock panel to make these work.
Please help!
ARAMP1 is offline   Reply With Quote
Old 04-03-2006, 10:27 PM   #2
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Re: PLEASE HELP With Q-Forms Kick Panels!
TTT...anyone?
Old 04-03-2006, 10:44 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Close up the air vent and forget it, and move the brake pedal, or get a hand brake to replace it. It should work
piecesparts is offline   Reply With Quote
Old 04-03-2006, 11:09 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
I have Q-forms and didn't have any problems installing them. Do you have the correct year forms for your truck?
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 04-03-2006, 11:19 PM   #5
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Interesting. How did you do the passenger side vent? Got any pics? I'll probably just cut the origional one out and go from there. I decided to re-check and I got part number QL-K1006 which is supposed to be for 80-91 truck and I've got a 90 (crew cab) My truck should be same as the blazer/suburban (and the same as you're 85) which is what these fit.
Old 04-04-2006, 12:09 AM   #6
swervin ervin
Yeah, the K1006 is what I have. Do you have a AC truck. These forms are designed to work with the AC vent, not the regular pull open vent. I think. As for the park brake hitting, you might need to adjust your cables so the pedal doesn't go so low. I can set my brake and the pedal is right above the form or grille without hitting. If I push down really hard, yes it would hit some.
I didn't need to modify anything to make them work. Just dyed them to match my interior color (which is black like my forms were), installed my speakers and put them in.
Old 04-04-2006, 12:36 AM   #7
ARAMP1
ROCK*STAR
ARAMP1's Avatar
What did you do with the vent on the passenger side?
Yeah, I have AC. The vent is the same, except the AC trucks had a vacuum operated vent and the non-AC trucks had a pull knob. The kickpanels were the same (although if you had AC, and hence the vacuum operated vent, you got a chrome button to snap in the hole where the bull knob would go.
You can see in the first pic there is the base model vent on top and the deluxe model vent (with kickpanel) on bottom and the Q-Form on the left. The next picture is of the Q Form on top of the stock panel. They really don't line up.
Old 04-04-2006, 11:16 AM   #8
chevyjr73
chevyjr73's Avatar
i didn't have any problems installing my kickpanels at all. i did have the same problem with the parking brake hitting the speaker. my solution was to remove the piece of rubber off the parking brake foot lever and it gives just enough room to slide by. hope they work out for ya.
chevyjr73 is offline   Reply With Quote
Old 04-04-2006, 03:01 PM   #9
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Hey CHEVYJR73,
It looks like you installed the Q-Form kick panel OVER the stock kickpanel. Am I right? Did you do it that way on both sides?
Old 04-04-2006, 06:46 PM   #10
chevyjr73
chevyjr73's Avatar
yes i installed mine over the stock kickpanels
Old 04-04-2006, 06:51 PM   #11
chevyjr73
chevyjr73's Avatar
just to be sure i went on qlogic's website and the installation instructions for the kickpanels do in fact say that they are installed overtop of the factory kickpanels.
Old 04-04-2006, 07:45 PM   #12
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Damn, they sure as hell are supposed to go on top! Wow! Thanks! I don't know what I'm going to do now. Here's a pic of 84PUMPKIN's panel that is against the metal.
Old 04-04-2006, 09:51 PM   #13
dx2995
Were did he get that kick panel?
1986 Chevy Short Wide. 305 engine. Power Everything. ( My kids Truck)
2004 Corvette Z06
2005 Ford Crew Cab F350 King Ranch 4x4
2003 Gmc Denali
2002 Ford Focus
dx2995 is offline   Reply With Quote
Old 04-04-2006, 11:33 PM   #14
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Not sure where he got his, but I got mine at CarDomain for 129.95+9.95 shipping.
Old 04-04-2006, 11:56 PM   #15
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Well, I really don't like the way they fit over the stock kick panels, so I've decided to mount the driverside Q-Form directly to the metal. The problem with the passenger side is the vent. I've modified the origional panel to use only the vent and I'll mount the Q-Form directly to the metal. Here is a pic of the before and after (and painted)
Old 04-05-2006, 01:25 AM   #16
obsesive23
Who me?
obsesive23's Avatar
Looks good
Living the dream
72 2WD Blazer, under going porter built surgery
67 GT Mustang fastback
67 Mustang coupe C/S clone
64 Falcon sprint hardtop
obsesive23 is offline   Reply With Quote
Old 04-05-2006, 02:58 PM   #17
SmittySmith
'82 GMC Sierra Classic
SmittySmith's Avatar
Is there any way you could put an offset bushing on the top of the emergency brake pedal to give it some offset, maybe 1/2 inch or what it needs to clear. That way you could keep the stock pedal, or you might could mod the pedal arm with a z-bend to give you the clearance... just some thoughts.
~Smitty
SmittySmith is offline   Reply With Quote
Old 04-05-2006, 04:35 PM   #18
ARAMP1
ROCK*STAR
ARAMP1's Avatar
~Smitty
Smitty,
I was planing on spacing the pedal over with a couple washers or something. I had thought about re-drilling the holes in the firewall and moving it over, but with the fuse box there, there isn't really enough room. The plan right now is to take the flat metal part of the pedal off and re-weld it towards the left side of the metal. That way, it effectively sticks over to the right.
Old 04-05-2006, 04:46 PM   #19
dx2995
What size speaker will the kick panels hold?
2004 Corvette Z06
2003 Gmc Denali
2002 Ford Focus
Old 04-05-2006, 06:18 PM   #20
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Definitely NOT a 6.25" speaker. See here.
Old 04-05-2006, 10:30 PM   #21
SmittySmith
That sounds like a good plan to me if it's just the flat metal part that is hitting, it would be a cool mod too since you would retain the original flat metal part and the rubber pedal giving it the semi-original but unique look.
I'd like to see a pic when you get it done.
~Smitty
Old 04-05-2006, 11:36 PM   #22
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Most Q forms will hold a 5.25" max. Add some sound deadner behind the panels to get better midbass.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 04-06-2006, 12:50 AM   #23
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Well, I re-welded the parking brake pedal over to the right. It moved about an inch! I'm waiting for the paint to dry right now, but that should help with the clearance issues.
Old 06-22-2006, 06:20 PM   #24
PHOENIX
I found this searching. Any updated pictures of the install?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 06-22-2006, 07:42 PM   #25
TEAM THC
CUSTOM CHEVY FIEND
TEAM THC's Avatar
Those Look Good! How Do They Sound?
THE QUEST CONTINUES TO BUILD A TRUCK WITH THE PERFECT BLEND OF OLD AND NEW SCHOOL STYLING.
SEE PROJECT PICTURES AT CARDOMAIN.COM. SEARCH MEMBER ID TEAMTHC
TEAM THC is offline   Reply With Quote
