Old 04-12-2006, 10:40 PM   #1
local13hutch
MEMBER
local13hutch's Avatar
Post Your 4wd Suburban Pics
Post All 4wd Suburbans, Any Year, Modified Or Stock! Let's See What You Got!
Here Is My '86 1ton, Custom, Duallie, 4x4, 468 Bb, Th475 Gm Motorhome Trans., Dana 60 Front, Dana 70 Rear, Arb Lockers Both, On-board 30 Pound Currie Compressor, Airbags In Rear For Towing, Class 3 Tow Hitch (forward And Rear) Hardwired For My Warn Winch & Plug-in Style Jumpers, National Springs All The Way Around, Dynatrak Crossover Steering, Dual Batts., Big Output Shaft 205 Transfer Case Married To 203 Transfer Case, Dual Set-up, 36" Tires With 4" Alum. Spacers.
I Built This Truck From The Ground Up 3 Times, Starting With Dana 44's, Small Block, 700 R4, 208 Tc. Blah Blah Blah.
I Have A '72 3/4 Ton Sub I Picked Up Cheap. The Guy That Owned It Put The Body On An 80's 3/4 Ton Frame And Running Gear. I Bought It Because I'm Going To Take The Body Off The '72 And Put It On My '86.
I've Got So Many Hours And $$$ In My '86 Already, This Is The Best Way To Go! I've Got All The Bugs Out Of My '86, And It Runs Like A Bat Outta Hell.
Future Plans: Body Swap, 4l80e, Man. Shift. This Eliminates The Need For Computer, Etc... I'll Use A Floor-mount Spring Retent Slap-stick. I've Got This Set-up In My C10 Pro Street.
local13hutch is offline   Reply With Quote
Old 04-12-2006, 11:04 PM   #2
Beast388
Suburbans RULE!
Beast388's Avatar
Re: Post Your 4wd Suburban Pics
Here you go!
Yea......she's cherry!!
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 04-13-2006, 07:51 PM   #3
1Ton
1Ton's Avatar
Heres my brothers:
The burbs life here:
http://www.burben.com/
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 04-13-2006, 10:24 PM   #4
Superron21
DONT TRY THIS AT HOME!
Superron21's Avatar
My 68 GMC 3/4 Ton 4x4
283 4bbl, n.p. 465 4 speed, rockwell t-221 transfer case, 4.56 eaton rear end (no spin locker) dana 44 closed knuckle front (open) front bumper made from 1/2 " plate, rear is 6" channel iron, 6" skyjacker soft ride springs/ shocks, extended braided brake lines.... future upgrades include such hi-tech add ons as power steering and brakes and a radio......
Superron21 is offline   Reply With Quote
Old 04-14-2006, 05:11 AM   #5
4x4Poet
Buwhahahaha!
What's that hook for, Superron21? Snagging obnoxious ricers?
IIRC, you found the front bumper is the right height to clip ricer wings.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 04-14-2006, 06:34 AM   #6
Superron21
Superron21's Avatar
you wouldnt believe how nervous people in nice shiny cars get when i turn on my signal, hold the steering wheel from underneath with my knee, then run my hands across the top of the wheel like I'm turning....
I've had people in the oncoming lane slam on their brakes..... dont get me started on the rice grinders and the bumpin music, ridiculous spoilers, bad haircuts and spinner wheels, the stereos have more power than the engines
Old 04-14-2006, 07:01 AM   #7
If it won`t go,buy a stereo.
Old 04-14-2006, 12:00 PM   #8
MrBinAz
MrBinAz's Avatar
And mine when I found her.......
-----the fleet-----
'72 K20 Chevy Suburban
'72 Datsun 510 (vintage racer)
'89 Honda Civic Si HB
'89 Honda Civic Dx HB
'08 Honda Element EX-P
'78 Honda Express (50cc. pit-ped)
pix here
MrBinAz is offline   Reply With Quote
Old 04-14-2006, 12:14 PM   #9
cheyenne10
cheyenne10's Avatar
quick pic of mine some time ago.
Bob
cheyenne10 is offline   Reply With Quote
Old 04-14-2006, 01:57 PM   #10
70rs/ss
70rs/ss's Avatar
When I get back on Sunday, I'll post some picts of my new (to me) 68 4X4!! This is the second 67-68 4X4 Burb I've owned, I sold the first to qksilver in NC, so I had to find another!! I've owned several 2wd Burbs, but I have a soft spot for 4X4, with four K5's, and two 4X4 Trucks to my credit!!
70rs/ss is offline   Reply With Quote
Old 04-14-2006, 09:20 PM   #11
RANDY COX
RANDY COX's Avatar
Here's my 90 and 70Name:  90 burb.JPG
Name:  lift with tires.JPG
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 04-15-2006, 12:20 AM   #12
longhorn71
longhorn71's Avatar
Here is mine.it is a 68 gmc 920(candian truck)it is all complete and original(no it has not be repainted either) It was a sepical ordered truck and these are the factory colors it was last on the road in 1973 and has 46000 miles on it I plan on getting it running this summer
longhorn71 is offline   Reply With Quote
Old 04-16-2006, 05:52 AM   #13
4x4Poet
Randy Cox, that three-tone paint job on your '70 works. I'd have never guessed.
local13, did you divorce mount the NP205 behind the TH475? Roughly how much longer is the TH475 than a TH350/TH400? Is the TH475 a 3 or 4 speed?
You've got one heavy duty rig, there. I think your rig's wheelbase is 5 or 6 inches longer than a 67-72 burb (126"), so be sure to measure carefully before body swappin' commences.
Old 04-16-2006, 12:33 PM   #14
RANDY COX
RANDY COX's Avatar
Thanks 4x4 poet that paint scheme was already on there when I got the burb as for the black on bottom that dark color hides all the holes,FOR NOW I too like the color scheme this vehicle came from henderson n.c.anyone recognize it,anybody.
1964 BBC 402 4x4
Old 04-16-2006, 09:21 PM   #15
local13hutch
MEMBER
Beast, Great shots. That dark green is my choice. My '72 is a metallic dark green, but it's not stock. When I get to that point, I'm going back to factory dark green maybe even that non-metallic hunter green or whatever it's called. I can tell by your action shots you have got the right combo of parts that ''beast'' performs.
86 sub 4wd, 1 ton, duallie, big block th475
72 c10 short fleet, pro street
72 K/5 blazer,2x4 almost stock
72 3/4 ton sub 4x4
61 morris minor pickup, chevy 4.3 v6
03 escalade, 24" momo's wifes
96 2wd 2door tahoe
67 2wd suburban
72 4wd k5 99 vortec 14bolt/d60 205/th400- 72 4wd crewcab 1 ton sb cummins allison -2012 2ss camaro black hard top- 8 yamaha quads- 05 4wd one ton duramax dually, family limo.
Old 04-16-2006, 10:18 PM   #16
local13hutch
MEMBER
Poet, The th475 is a th400 with flat cut gears instead of helical cut or angle cut gears. They only came in GMC motorhomes. I don't think they were ever factory on any 4x4 vehicle. They whine a little. The design idea is once the trans shifts, the gears ride flat against each other instead of constantly riding at an angle and pushing away from each other, creating more wear and friction. Perfect application for pulling, but not for a ''hot rod'' application. It shifts a little rough compared to a basic th400 . So externally same dimensions as th400 and it is married to my 205. I have the planatary half of a 203 bolted to the after end of the 205, making it a doubler set up so my driveline is a bit shorter than stock. It works perfect. Also, the average temp is dramatically decreased. I run a trans pow-steering radiator and brake fluid external coolers. It is a 3 speed. Thanks for the info on wheelbase length, I wasn't aware of the difference. Hey guys, keep in mind I'm not a transmission transfercase expert but I've been on a crash course since I started working on this truck about ten years ago. I'm getting there out of neccessity. But you get the basic idea, I hope. local13.out.
72 3/4 ton sub 4x4
96 2wd 2door tahoe
67 2wd suburban
Old 04-17-2006, 06:30 AM   #17
Here`s my`91:Fleet-owned by WashingtonSuburbanSanitaryCommission(Sewer & Water for DC),6.2,4L80E,4.10,G60,Warn manuals,3" duals,4" TuffCountry springs,& Goodyear MTRs.
Plans are to remove body,fit`69 1ton cab`n`clip,low-profile Reading utility bed,& K/30 axles.
Old 04-19-2006, 12:01 AM   #18
local13hutch
MEMBER
Special K. Nice ride, great idea. Your 80's and 90's erra frame is a good choice. In my experience the 60's and 70's frames are a bit flimsy. This is my reasoning behind my 86 sub chassis being used for my 72 body transplant, that and the fact I've got about 90% of my overall labor and $$$'s in the frame itself.
72 3/4 ton sub 4x4
96 2wd 2door tahoe
67 2wd suburban
Old 04-19-2006, 11:22 PM   #19
local13hutch
MEMBER
Here is a picture of my 86 and 72 subs soon to be joined forever. I am taking off the 86 body and replacing it with my 72 body. see pic's this is my homemade photo chop-scissors-copy- style ''duh''.any way you can get the basic idea. Keep in mind this is my first attempt at photo alt, It would have probably been easier just to do the swap and take the pic's.
In the bottom pic I used the existng dual fender but I have a pair of after market step side fenders that are 4'' wider than stock, so the finished product will have matching round wheel wells. local13hutch Out.
Engineering.
72 3/4 ton sub 4x4
96 2wd 2door tahoe
67 2wd suburban
Old 04-21-2006, 04:03 PM   #20
Beast388
Suburbans RULE!
Beast388's Avatar
Thanks!! Actually the only part that is green is the hood. Orginally the Burb was yellow. An engine in 1992 totalled the truck and warped the hood so bad that water would pool there when it rained. So, a junkyard hood sits in its place.
I do enjoy taking the old girl offroading. I figure that the body is so shot that it really doesn't matter if I scratch or dent it.
--Ben
71 GMC Suburban 4X4
The "Beast"
Old 04-21-2006, 04:04 PM   #21
Beast388
Suburbans RULE!
Beast388's Avatar
There are some nice Burbs in this thread!!!
--Ben
71 GMC Suburban 4X4
The "Beast"
Old 04-23-2006, 07:42 AM   #22
vtblazer
vtblazer's Avatar
72 3/4 ton burb.
vtblazer is offline   Reply With Quote
Old 04-30-2006, 11:33 AM   #23
ABHaulR
ABHaulR's Avatar
heres my ride..
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 04-30-2006, 11:36 AM   #24
ABHaulR
ABHaulR's Avatar
heres a brothers truck show pic..
Old 05-02-2006, 03:33 AM   #25
local13hutch
MEMBER
ABHauleR...Man your truck is beautiful. I have got a 72 chevy sub Im working on and seeing yours reminds me of what these trucks are all about and why I do what I do.thanx for sharing the pic's.
72 3/4 ton sub 4x4
96 2wd 2door tahoe
67 2wd suburban
