I have 1 1/2 drop shackles coming. Next I want to lower the front the right way. I want the front to set the same but I don't know what to order. now the coils are cut. I want drop spindles but what sprinds do I need? Tires are 275/60-15.Thanks.
![]() ------------------ 69 short box 4x4 72 long box 69 Camaro 327 4-speed 71 4x4 suburban, soon to be crew cab short box 87 S-10 V-8 FOR SALE Des Moines, Iowa [This message has been edited by Brian19692 (edited April 20, 2002).]
67 short 2wd. FOR SALE 69 long box w/72 grill 69 Camaro 327 4-speed Des Moines, Iowa |
http://community.webshots.com/user/hotrodhorn |
Thanks Longhorn.
------------------ 69 short box 4x4 69 long box w/72 grill 69 Camaro 327 4-speed 71 4x4 suburban, soon to be crew cab short box 87 S-10 V-8 FOR SALE Des Moines, Iowa
if you have 1 full ring off the coil,you can figure about 2 1/2-3" drop on front.....69
its all about the +6 inches
If you run stock springs with teh 2 inch spindle, you'll get a stock ride. Any more than 2 inch drop with springs, you may start having geomitry troubles.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
I agree....i am running a cut coil,& this is not the way to go(2" max on the spring should be ok). I plan to use a 2 1/2" spindle,with a 1 " drop spring to get the drop that i want,& bring front geometry back into spec.........69
Got 20's????
Hey Brian. Here is what my truck looked like with just the drop shackles and drop coils (not sure how much coils are though).
![]() ------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
