Old 04-20-2002, 02:58 PM   #1
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post Need help with what drop I have
I am supposed to have 2" drop springs. With 275/60/15 tires on 15X8 wheels the bumper sits 8 1/2" off the ground measuring from under the liscense plate. Are these 2" coils? It seems like I went more than 2" down and it sits on the rubber bump stops. I also measured from the ground to the fender lip is 27 3/4 with 255/70/15 tires.
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 04-20-2002, 03:04 PM   #2
Lumpy
2 tons of fun
Lumpy's Avatar
Post
I have 2" drop front springs on my 67. I have 255/60/15's on the front and i measured my bumper to ground distance and it is 10 1/2". I measured from the top of my fender well to the ground and it was 29". SOunds like you have a 3" drop if not more. Lumpy
67 Chevy,Short/Fleet,350,Saginaw 4-Speed,Lowered 4x2,small window,P/S,Edelbrock Intake/Carb,HEI,Gear Drive,Crane Cams 274h
Three Rivers, Ca
Pics at: http://community.webshots.com/album/35751472Gxaqxf
67 Chevy,Short/Fleet,350,Saginaw 4-Speed,Lowered 4x2,small window,P/S,Edelbrock Intake/Carb,HEI,Gear Drive,Crane Cam 274H
Three Rivers, Ca
Pics at: http://www.cardomain.com/id/lumpy454
Lumpy is offline   Reply With Quote
Old 04-20-2002, 05:32 PM   #3
Alexis
Member since 2000
Alexis's Avatar
Post
mesure from the center hub to the fender, then it easyer to tell cause not all bumpers are bolted on to perfection
Mechanic @ California Concept
Britney: 1970 2wd K/5 Blazer (Frame up)
Jessica: 1967 2wd SWB (pops daily driver)
Helga: 1972 4x4 3/4ton LWB (my daily driver)
AIM:Alexmart1
Mountain View, Cali
Alexis is offline   Reply With Quote
Old 04-20-2002, 05:47 PM   #4
69 longhorn
Post
From the ground to the fender lip on my longhorn is 27 3/4". I have a 1 1/2" body drop,& a cut coil drop(my guess is 2 1/2-3 "on suspension....4-4 1/2 " total drop). The front tires are 225/75/15(28" tall)....69 longhorn
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
