![]() I own a 1969 C/10...350/auto....In 3 years I have replaced 3 starters and 2 alternaters....I just put on alternator number 2 last week and it lasted one day before the lights went dim and the generator light came on.....The truck still ran for the next 3 days but finally quit and won't turn over now....I know the charging system is not working but can't find out why it is ruining the new alternator....PLEASE HELP.....I need some answers. Johnny |
its all about the +6 inches
is your harness all messed up? Look for corroded connections on your regulater and shors in the other harnesses, or real crappy repairs.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
I bought the truck 3 years ago and have never done anything to it.....I have never touched the harness or wiring....The truck always ran strong and started fine.....I just put a new carb on and replaced the distributor with a new one.....I drove it 540 miles to Chicago without a glitch and now all of a sudden it craps out.....Thanks for the suggestion.....I will replace the voltage regulator next and even maybe the coil since I know the coil is original
Can't kick the addiction!
Sounds like your regulator is screwed up. What style regulator in the truck, the new electronic style or the old adjustable kind?
I believe it is the old style regulator.....its a rusty black box mounted next to the radiator
Replace the regulator. I had a similar problem with my 72 c20 and it was the regulator causing the problem.
Thanks zyggy72.....I'll try that next....
Binder Rep
if it keeps up, run new wiring for the regulator and alternator *AND* new battery cables.
Old member
Throw away that regulator and spend the extra money for new alternator with built in regulator! It will make your truck run better and your life will be a lot easier. You can buy one that fits all of your brackets and not have to do nothing but bypass the wiring harness to the regulator.My father-in-law went through about five regulators before I got him to change over,and never had another problem after that.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 71,factory tach,tilt for straight drive,gauges,ac,305 HO TPI with 700-R4 lowered,17" wheels www.geocities.com/chevy71tpi/main.html] www.picturetrail.com/Andy4639]
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
You can buy internal regulated alternators on Ebay. New rebuilt 135 amp, for $48. Place called alterstart.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
I had similar problems and it was the regulator. I bought the cheaper electronic solid-state one instead of the adjustable one but seems to work
I'll probably regret the cheaper electronic one later on and end up going back to the old adjustable ------------------ Nick Rodenberg Wellington, MO http://nickrod.port5.com You can click on "My 72 Chevy Truck" I have a 72 Cheyenne 10 with a V8 350 and a TH-350 auto-tranny. Ochre/White/Ochre Runs well... working on body. Plan to get painted weekend before memorial day weekend. Planned to be done March 7 when I turned 16. Didn't happen. Chose to do better job and be behind schedule instead of 1/2 doing it and it looking like junk.
Nick Rodenberg 72 Cheyenne 10 V8 350/TH350 white/ochre/white/ochre, ochre/saddle interior Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!! |
I just got done converting to int. regulated(hands are still dirty) and it was simple. The alt was given to me, and the junk yard didn't charge me for the pig tail...they laughed at me when I asked how much.
I can see my lights being brighter too. pretty cool. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
