05-18-2006, 08:34 PM | #1 |
Identify Radio? Will it FIt?
I found this radio in the box of my truck when I got it home!
Does anybody know what chevy it is out of? Will it fit in my stock '69 dash? The sticker is still on the side and reads: Part no. 16009960 service ref. no. 30BCMS1 [IMG][/IMG] [IMG][/IMG] Thanks in advance!
1969 Chevrolet Longhorn C30 - 350, 4-speed |
05-18-2006, 08:41 PM | #2 |
Re: Identify Radio? Will it FIt?
Why don't you see if it looks like it will. I would be it does.. That's how mine was.
05-18-2006, 08:50 PM | #3 |
its all about the +6 inches
late 70's early 80's GM something or another.
05-18-2006, 10:25 PM | #4 |
As usual Andy is on top of it. I don't think they fit because then everyone would have am/fm,cassette,CB etc.
Don't take my word for it though. Walk outside and try it. Good luck - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
05-18-2006, 10:35 PM | #5 |
I'm thinking the face will be too tall on that radio. Looking at it, and picturing a DIN sized stereo.... that face looks about an inch too tall.
05-19-2006, 12:23 AM | #6 |
Looks like what came out of my 82 Caprice. Way too tall to fit the truck!
I tried. |
05-19-2006, 09:41 AM | #7 |
More Cowbell....
Been down that road already. YES AND NO.
It will not simply FIT into position, but it can be done. I had to modify the back of the radio itself to force it to fit. It will touch the backside of the cowl unless you cut the radio case down. And the shafts aren't centered in the holes either. You can fashion yourself some washers and drill the holes off-center to help finish out the install or make a trim panel out of thin aluminum. And lastly, you WILL have to cut your dash. Like Longhorn Man mentioned above, this one is way too tall for the stock opening. I made mine fit, but would not do it again. Look closely...you can see it in the dash of my old cab.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 05-19-2006 at 09:43 AM. |
05-19-2006, 07:10 PM | #8 |
Who's got steelies?
Yeah, I got one of these from a junk yard about a month after getting my truck. Big dissapointment when I found out it wouldn't fit. I ended up bringing the original AM radio back to life by installing a new speaker, and cleaning the volume pot, but would really like to have the FM WITH the mechanical push-button tuner. Some day....
Truck is too loud inside to be able to hear the radio anyway!!
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
05-19-2006, 09:19 PM | #9 |
Thanks for all the replies....I think i will just keep my 80's aftermarket deck in for now, I guess that is why it was in the box of my truck and not the dash!
05-21-2006, 07:19 AM | #10 |
The dial portion of the stock radio measures 4 3/8" X 2 1/8". Knob shafts are 6 1/4" center to center. The distance between the knobs can be adjusted on some radios.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
05-12-2008, 03:24 PM | #11 |
I like to know if this radio fit in my 71. Are you able to identify the radio with the part number on the picture 7303275. Thank's
'71 Custom/10 Deluxe LWB '71 Custom/30 Deluxe Dually |
05-12-2008, 04:14 PM | #12 |
syncrov69...just use the measurements I stated in previous message. The dial portion does not appear to be the right size for GM radios used in our trucks.....
08-14-2008, 06:30 PM | #13 |
i think that radio is out of a vet.
