Old 04-21-2002, 09:15 PM   #1
BUXMAN66
go bucks!
Post leery of drillin'hole in my baby!
got my new mirrors from pauls,now i'm gettin' anal retentative bout drillin' a 'coupla holes in my nice orange paint!how many beers is recommended to start this?
'68 swb 350/350 w/edelbrock total performance-performer pkg.ceramic headers,2.5" delta-flow 40 series flowmstrs.no rust of the notorious mid-west on this one! see my truck at free photo-i under "'68 chevy truck"
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 04-21-2002, 09:18 PM   #2
BubbaGreen
Post
NONE! But keep at least a case handy, just
in case you slip! :-)
71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73
See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
BubbaGreen is offline   Reply With Quote
Old 04-21-2002, 09:21 PM   #3
Andy4639
Old member
Andy4639's Avatar
Cool
Back yearsssssssss ago me and a buddy had drank a COUPLE of beers when we decided to put my sun roof in my LUV truck, yes a LUV truck. It was my 1st. new truck after intering the work force. Kept that truck almost 5 years and never had a leak in it except for when I would forget to close it at night and it would ran. Make sure to measure it a few times before drilling. Tape over the paint also it helps to keep from scrathing and ops'es from happening.
Andy
71's Are for ever!!! or 67,68,69,70,72
71,factory tach,tilt for straight drive,gauges,ac,305 HO TPI with 700-R4 lowered,17" wheels
www.geocities.com/chevy71tpi/main.html
www.picturetrail.com/Andy4639
[This message has been edited by Andy4639 (edited April 21, 2002).]
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-21-2002, 09:22 PM   #4
69 longhorn
Post
I reccomend the beer AFTER you drill the holes! ......69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-21-2002, 09:23 PM   #5
BUXMAN66
go bucks!
Post
brought home a spring-loaded center punch from a buddy at work,keep using the excuse that it's too cold(44deg.this afternoon)to go out to the garage.guess i'm just bein'chickens#$t!!
Old 04-21-2002, 10:12 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Just use a hammr and a punch!
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-21-2002, 10:50 PM   #7
fine69
fine69's Avatar
Cool
Ok, easy one here. Use the spring loaded center punch. Then take some good quality masking tape. Bodyshop 3M is best. Put several peices around each hole to be drilled. This helps keep the drill bit from walking on you. And if it does it gives you some protection from deep scratches. Start with a 1/8 inch hole first. Dont try a huge bit first. Bigger the bit, the bigger chance your gonna screw up.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 04-21-2002, 10:58 PM   #8
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Post
Tape before you center punch! It will help keep the paint from chipping around the punch. Good Luck.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 04-22-2002, 03:28 AM   #9
BUXMAN66
go bucks!
Post
well, i definitely ain't using a hammer&punch!lol lol that's a good way of making a bigger prob.!a spring-loaded center punch is controllable and is the only way to go to keep from walkin' on ya and not havin'a dent on your door! i'm also using tape and a tape measure,just chicken to start(kinda,you know,conversationally...?)made me some backing plates at work,welded some nut's on over the holes i drilled in the steel plates.should have good structural integrity as i made them wide,and long enough to handle the load of a small toddler to hang from 'em!
Old 04-22-2002, 06:48 AM   #10
Mike C
Mike C's Avatar
Post
Definitely tape BEFORE you do anything else. Drill very slowly and try to avoid sharp edges or distorting the metal with pressure on the drill. And good luck!
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
Old 04-22-2002, 09:24 AM   #11
Longhorn Man
Post
Just messin with the hammer thing!!!
I would touch up what ever you do chip...also inside the hole too. And since it will be hidden, it don't matter that you don't have any more orange to touch it up with.
Old 04-22-2002, 09:38 AM   #12
Desert Rat
Desert Rat's Avatar
Post
DEFINETLY use tape where your drilling to avoid chipping scratching etc,and cerainly do as mentioned before start with a small drill bit and work your was up.Just heard all this the guy who painted my Blazer welded up all the holes now i need to drill holes but im going from them ugly camper style mirrors,i may use 72 Chevy truck style.Wait on the beer from experience-itll look all good and done,then the next day youll be wtf did i do???
Desert Rat is offline   Reply With Quote
Old 04-22-2002, 09:40 AM   #13
Desert Rat
Desert Rat's Avatar
Post
OH and use a new or very sharp- bit not the rusty one you found at the junkyard!!!a sharp bit makes all the difference in the world.
Old 04-22-2002, 12:03 PM   #14
BUXMAN66
go bucks!
Post
nice thing 'bout working in a machine shop you have access to all kinds of tooling & stuff.got me a cobalt drill bit 1/32"started by a 60 deg.center-step drill.heh! heh! followed by a "p" drill (.332")for the actual dia. of the s/s outside screw.
