Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 10-02-2006, 10:54 AM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
My modified van tilt column
Finally remembered to take some pics of my tilt column that I installed a month or so ago. This is a mid 70's automatic van tilt column that I modified for my manual 4 speed truck. That involved shaving off the tilt shifter attachment point and removing the shift indicator housing and filling in both areas.
Here are some pics of the modification process.
I cut a beer can up to fill in the various holes and used JB weld to secure them and fill in the areas.
Then ground it smooth.
And here is the finished product.
Not sure if I like the steering wheel - might change it down the road.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline
Old 10-02-2006, 02:30 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: My modified van tilt column
Here's some more info. I added a Borgeson telescopic shaft (1" DD x 3/4" DD) to my 69 K20. I had previously added a Borgeson U-joint at the steering column.
Here is a pic of the u-joint which is 3/4" x 30 spline and 1" DD to fit the power steering box I'm using which is from about a 1978 Chevy 4x4.
and a pic of it at the steering column - the steering column was not secured to the firewall when I took the picture so ignore the block of wood that has the column wedged in place. That U-joint is 3/4" x 36 spline and 3/4" DD.
The telescopic shaft ended up being about 11 1/2" long.
Closed Thread
