Old 03-21-2002, 08:00 PM   #1
mooneyes
mooneyes's Avatar
Post vortec heads?
i dont mess with the newer small blocks much...was wondering if someone can tell me why the vortec heads need self aligning rocker arms?..can you just change the studs and use regular rockers? thanks
70 short step from vegas woo hoo !!!Ken Lyons Slippery Rock PA yahoo messenger:mooneyes4b "things always look different from higher up" Clint Eastwood (fist full of dollars)
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 03-21-2002, 08:31 PM   #2
69 longhorn
Post
On the older heads, the holes for the push rods were tight enough to keep things in line. Only the hot factory stuff had guide plates on the small block. I havent taken a look at the Vortecs, but my guess is that the push rod holes are too big to keep the rockers in line with the valve tip......69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-21-2002, 08:36 PM   #3
mooneyes
mooneyes's Avatar
Post
and what exactly do the self aligning rockers do? never seen a set
78 caprice project
Old 03-21-2002, 10:46 PM   #4
bigjimzlll
bigjimzlll's Avatar
Post
align them selfs?...lol...I dunno but was wondering the same thing
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-21-2002, 11:07 PM   #5
Luckymic34
Whisky Bent & Hell Bound
Luckymic34's Avatar
Post
I just bought a vortec head conversion kit and when I opened the box for the self aligining rockers (because I've never seen'em before) I thought to myself I hope Randy knows how to put'em on cause I sure dont. They look the same as regular rockers, but they come with two funny looking washers.
68 custom stepside
350 with Carter 650, Weiand intake, HEI,
Crane Enegizer 266 cam, Headmen headers
40 series Flowmasters, B&M hole shot
2,000 rmp stall, TCI TH350 Streetfighter,
4.10 gears
Virginia Beach, VA by way of
Houston, TX
68 custom stepside PS,PB
350 with Vortec Heads,Carter 650, Edelbrock Performer,HEI,
Crane Enegizer 266, Headmen headers
4.10 gears
2003 Harley Davidson 883C
San Diego, CA by way of
Houston, TX
Luckymic34 is offline   Reply With Quote
Old 03-21-2002, 11:59 PM   #6
rcbildr
rcbildr's Avatar
Post
I built my 350 with vortec heads a while ago. 69 longhorn is right... the holes for the pushrods are too big to keep things lined up. The tip of the rocker is shaped differently so that it stays on the rod. If you don't want to use slef aligning rocker, you can also use guide plates. Hope this helps.
71 C-10 1/2ton, Dual 2 1/4" exhuast, painless wire harness, rebuilt TH-350, 355 with vortec heads, silvolite hypereutectic dished pistons, ARP rod & main bolts, edelbrock performer intake, blue racer cam int. 214 exh 224 @ .050, melling high volume oil pump, double roller timing chain, edelbrock performer carb, and HEI ignition with Accel Supercoil & module.
Daily driver: 89 Pontiac Grand Prix 2.8L V6 w/ 5spd manual
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 03-22-2002, 07:36 AM   #7
Blazer1970
Blazer1970's Avatar
Post
The self-aligning rockers have a notch where they sit on top of the valves, instead of just a flat area like an old style rocker. This way, they always stay centered on the valve, and that keeps the other end from being able to move, thus keeping the pushrod aligned. This way, they don't have to run a tight clearance on the pushrod holes in the head or a guide plate, which cuts down on friction in the valve train. If you want to, you can pull out the studs, thread the holes, and use threaded studs with guide plates for the pushrods. This is normally done on higher performance set-ups where you want to use fancy roller rockers. There is a lot better selection of old style un-guided roller rockers than the guided style. The threaded-in studs also are a lot stronger which is an advantage if you are running a very aggressive cam, high ratio rockers, or stiff aftermarket valve springs.
Blazer1970 is offline   Reply With Quote
Old 03-22-2002, 07:51 PM   #8
mooneyes
mooneyes's Avatar
Post
thanks guys cant beat the price of vortecs and i wanted to know what i was getting if i do decide to buy them,,you guys answered everything i needed to know ....thanks again
78 caprice project
