Old 12-18-2006, 12:03 AM   #1
poorboy
poorboy's Avatar
A/C compressor conversion
I've heard you can convert an old a/c pump to fill air bag tanks. Does anyone know what needs to be done. I would also think I would need some kind of swith to turn it off and on like a home compressor. Any ideas.
poorboy is offline   Reply With Quote
Old 12-18-2006, 11:52 AM   #2
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: A/C compressor conversion
Look for a York 210 compressor. You'll need to fab up mounting brackets, or find someone to make them. I'm not sure what all is involved in the plumbing, but it should not be that difficult.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 12-18-2006, 01:15 PM   #3
Rollie396
someday it will be done!
Rollie396's Avatar
I'm in the homework stage of this mod too.It's looking like the main problems will be 1.mounting (have to fab own brackets and find the room to put that big sucker) 2.connecting airlines,because apparently the connections to the pump aren't NPT,though I hear kilbyenterprises can help with that.3.pulley to run it.This won't be a problem for me so much cuz I'm running a v belt,but if you're planning on a serpentine system,then you'll be needing to talk to kilby again .
anyhow,here's some reading for you.If you need anything else,I got lots of results when I googled "onboard air".Have fun with it!
http://www.bagginit.com/york_page_1
http://www.jedi.com/obiwan/jeep/yorkair.html
http://www.kilbyenterprises.com/faq.htm (a good diagram to give you an idea of the set up on this page)
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 12-18-2006, 05:05 PM   #4
poorboy
poorboy's Avatar
My truck already has a York and the brakets. Here's some pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=219766
I also found this on the web
http://coloradok5.com/york.shtml
Old 12-18-2006, 07:01 PM   #5
short step
look around in offroaders.com or kilbyenterprises.com/oba-scem.htm
offroad guys use them all the time
short step is offline   Reply With Quote
Old 12-18-2006, 08:30 PM   #6
77 burb
pirate4x4.com
click on bulletin board then
click chevy look through build ups
lot of guys use stock ac comp to run air tool off road
84 burb soon to bag and drop
bagging it,shaving bumpers(f/r)
shave tail lights(leds below tail gate)
updated flat door handles(chevy)
leblancinva@yahoo.com
77 burb is offline   Reply With Quote
Old 12-18-2006, 10:11 PM   #7
jimmydean
jimmydean's Avatar
Wow, I had something like that for the JC Penny A/C unit that my truck came with. I ripped all that crap out when I swapped motors. The PO took the belt off the compressor in an attempt to save gas and I sure didn't want to tran and deal with it.
jimmydean is offline   Reply With Quote
Old 12-19-2006, 01:37 AM   #8
SlammedDime
SlammedDime's Avatar
I also have an almost complete how-to at http://www.airridetalk.com/tutorials.../air-on-demand. Its more complete than the one at bagginit.com, and it actually has pictures.
Matt
Admin @ AirRideTalk.com
Win FREE Viair compressors!
SlammedDime is offline   Reply With Quote
Old 12-19-2006, 11:19 AM   #9
bodydropped
ur york should work all u need it to put an air filter on one side and and run the other side to ur tank but figure how to use a pressure switch or toggle switch to kick out the comp when ur tank is up to pressure
bodydropped is offline   Reply With Quote
Old 12-19-2006, 01:05 PM   #10
jimmydean
jimmydean's Avatar
SlammedDime, thanks for the link. I may look to make this change at some point since I have a feeling I will play with the switches more than I thought I would in the beginning.
Old 12-19-2006, 02:17 PM   #11
pharcyde05
pharcyde05's Avatar
hear is a link there are cpmpressors and brackets i have put 2 of these on one on my 2000 silverado and one on a 2002 S-10 you need a tep switch to shut it off if it gets hot and a pressure switch to shut it off when tank is full you can run them bolth through a relay connected to the clutch on the compressor
it creats a lot of heat so you need a leader line that will withstand alot of heat and pressure for the first 2 feet or so out of the compressor so the air has some time to cool off and a check valve at the tank is a good idea so you dont get blead back once the compressor is off
http://www.airbagit-store.com/produc...ory.asp?id=542
pharcyde05 is offline   Reply With Quote
Old 12-19-2006, 03:19 PM   #12
SlammedDime
While I'm sure the Sanden compressors are great if properly installed, they require more maintenance than a York, and on top of that, I would not buy anything from AIM if you could help it. I can't recommend enough that everyone stay far away from that company.
Matt
Old 12-19-2006, 05:24 PM   #13
pharcyde05
pharcyde05's Avatar
yea i know what you meen its was just where i knew had good pics i went down to my local AC shop and had them rebulid me a comprossor that i got from a wrecking yard and built a bracket desighned after the aim bracket put a oiler on one side and a seperater on the other side and it has worked great for 3 years
i know peoepl that have had problems with bolth the sandedn and the york if teh sanden gets hot you have to change the plate under the head and i know some guys that have had the york rod snap and rod bearings go out
i prefer belt drivento elect always though much more vol and quieter
Old 12-20-2006, 12:20 AM   #14
CHAPS7931
CHAPS7931's Avatar
http://www.jedi.com/obiwan/jeep/york_mounting.html
http://www.capitalcitycrawlers.com/OBA_System.htm
http://www.geocities.com/spencerhut/truck/air.htm[IMG]
http://www.toyotaoffroad.com/Article..._board_air.htm
http://www.toyotaoffroad.com/Articles/Projects/on_board_air/on_board_air.htm[/IMG]
but it should be easy on your set up i would think since its already there just run the hose
CHAPS7931 is offline   Reply With Quote
Old 12-20-2006, 12:22 AM   #15
CHAPS7931
CHAPS7931's Avatar
Old 12-21-2006, 06:34 AM   #16
jimmydean
jimmydean's Avatar
Anyone make a bracket to mount the York on a older V8? I feel like a jackass for tossing all that crap last year.
My engine is newer than my truck. My alternator is on the passenger side if that helps at all.
Old 12-21-2006, 07:06 AM   #17
Col Clank
http://lowriderimpala.com/products.html
If you look through this guys 64 Impala build he has a full pic set of the brakcet he fabbed etc, Overpriced but if you have any fab skills not hard to remake.
Col Clank is offline   Reply With Quote
Old 12-21-2006, 11:07 AM   #18
poorboy
poorboy's Avatar
I can take mine off and take a pic for you.
Old 12-21-2006, 03:23 PM   #19
Col Clank
would you please I would like to see it also
Old 12-22-2006, 05:22 PM   #20
XXL
Seņor Member
XXL's Avatar
More info on this conversion...
linky clickie thing
XXL is offline   Reply With Quote
Old 12-22-2006, 08:55 PM   #21
454_72_4X4
454_72_4X4's Avatar
I have a York compressor out in the shop right now. It came off of a chevy truck with a small block in it. I've been saving it for the same type of conversion but I can take pics of the brackets.
I might be able to build a duplicate set of brackets also. (Depends on just how complicated they are! LOL)
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-23-2006, 01:54 AM   #22
poorboy
poorboy's Avatar
Here's some pics. It's kinda bulky but it's from the 60's. It has a spring loaded tensioner.
Old 01-01-2007, 02:32 PM   #23
jimmydean
jimmydean's Avatar
I've decided I am going to start looking at compressor options. I was reading an article about using a non-York compressor and adding a tool oiler. I think I will see what I can find to mount on the drivers side that is small enough to deal with.
Old 01-01-2007, 08:50 PM   #24
short step
http://www.lowriderimpala.com/yorkupdate
Old 01-01-2007, 09:33 PM   #25
jimmydean
jimmydean's Avatar
I meant something other than a York to mount on the driver side. I will go to the yard and find something to pull and convert. I'm thinking a stock GM compressor with all the brackets, pullies and stuff.
The york is a good option, but looks awful. No matter how you mount it or set it up, it looks out of place (that's why I tossed it in the first place).
