Old 01-13-2007, 01:21 AM   #1
RetroSBK
1974 Blazer doors?
FNG here, did a seach, but nothing came up indoer replacement door, etc etc...
Does anyone know of a company that is making a door that will fit the demolished one on my 74 Blazer?
Everywhere I look Im told to buy the Truck door and cut the frame off...
Is that it? Seems like SOMEONE woudl make a door for this thing!!!
RetroSBK is offline   Reply With Quote
Old 01-13-2007, 01:41 AM   #2
gmcman7202
Active Member
gmcman7202's Avatar
Re: 1974 Blazer doors?
i take it you got the full removeable top ? caus otherwise the regular door would work. just cut off the truck door, but then add a plate inside for the support.
gmcman7202 is offline   Reply With Quote
Old 01-13-2007, 01:42 AM   #3
ItsNotABlazer
The full convertible guy
ItsNotABlazer's Avatar
If you look at the factory door they basically did the same thing.....cut off the top of it. I was planning on doing that on my 74 when it comes time to replace the doors. I do not believe I have ever seen any aftermarket companies advertising these doors so your best bet would be to cut some yourself.
2012 Kawasaki Vaquero (Lime Green)
2000 BMW 740iL
1995 Chevy ECSB riding on air
1975 GMC Jimmy 2WD lowered 4/6
1972 Chevy Trazer soon to be roadster
1965 Mustang 289/3 speed (friends dad bought it new)
1964 Chevy C10 (dad bought it new)
ItsNotABlazer is offline   Reply With Quote
Old 01-13-2007, 01:43 AM   #4
ItsNotABlazer
Oh and btw....welcome to the board from TX!!
2000 BMW 740iL
Old 01-13-2007, 01:49 AM   #5
Zoomad75
K5Camper
Zoomad75's Avatar
I hate to say it, but even LMC doesn't have doors for 73-75 K5's. If LMC don't have it, it's probably not being repoped... So unless you happen to come across an actual NOS door, your stuck getting one from a later Blazer or truck (they are the same) and cutting the frame.
If the door isn't smashed to bad, you might be able to get away with just putting a skin on.
Still Cutting full doors down isn't that difficult. Salvage the rubber cap off of the top of the a-pillar, the fiberglass cap for the rear and the tin support under it off of your old doors. You'll need them to put back on the cut doors. Follow the write up on CK5.com for the details of how to cut the doors.
My doors aren't caved in, but the bottoms are rusty. I'll probably have to fix the lower sections before long..
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 01-14-2007, 12:11 PM   #6
bagged74
its just $$$$$
bagged74's Avatar
Even if you order a door from GM it is a truck door with a template to use for the cutting. The doors are the same. just put the little support bracket back inside the door at the rear when you cut the top off of it.
bagged74 is offline   Reply With Quote
Old 01-16-2007, 07:01 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Ditto on what everyone else has said. There isn't a door availible that is already cut. You will have to cut it to make it work.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-17-2007, 01:10 PM   #8
Jonboy
Slots go on anything!
When GM offered a replacement door for the 73-75 Blazer, it was a truck door, a template, a filler, and instructions. BTW, if you were going to add power windows, this would be the time to upgrade to the 77-up doors.
Old 07-11-2012, 02:19 PM   #9
AKNeal
I don't mean to bring up such an old post but I have a 1973 K5 that I need to get new doors for. I'll probably grab some 80's model doors with electric windows and what not. I am just curious where I can get the template to cut them. I also want to know where to place that bace on the back of the door. I did a google search and this forum was pretty much the only thing that came up. Is there a how-to somewhere out there that can assist me further. I think the current doors are replaements and they weren't done right. The windows do not roll up if they are left down too long. They come off the track. So I want to make sure I do it right this time. Also, does anyone know a good place to get fiberglass replacement doors? (off topic, I know) Thanks!!
AKNeal is offline   Reply With Quote
Old 07-16-2012, 09:16 PM   #10
Ford Assassin
Ford Assassin's Avatar
http://coloradok5.com/full-convertible-conversion.shtml
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 07-21-2012, 01:18 PM   #11
closer9
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
closer9 is offline   Reply With Quote
Old 07-22-2012, 06:51 PM   #12
AKNeal
Old 03-03-2015, 08:33 AM   #13
windwalker
looking for templates to cut doors for 1975K5 full convertible don't want to make any
mistakes on this can any of you folks help out.
windwalker is offline   Reply With Quote
Old 03-03-2015, 09:25 AM   #14
Eyegore
What Hump?
Eyegore's Avatar
Windwalker see the post above from FordAssain with the link to Colorado K5
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
