Old 03-22-2002, 05:24 PM   #1
69sixpackbee
Post Okay You Tilt Column Conversion Experts...Help!
I got a tilt column out of a '76 Chev van today and I need to know what I need to do to put it in my '72 C-20. I heard the buzz about the difference in lengths...if so, how much? Where do I compensate during the install for this?
Will the guts (turn signal cam/flasher switch) from my original one swap into the van column? Mine is a 4 speed and the van column is an auto one. I am taking off the indicator and levers and will try to figure out a way to cover 'em up so it won't look too obvious. Will the housings (indicator & shifter arm with the non-indicator from my orig.)
swap as well?
Thanx!!
69sixpackbee is offline   Reply With Quote
Old 03-22-2002, 05:39 PM   #2
Southpa
Southpa's Avatar
Post
Hope this helps, it sure helped me...
http://www.net1.net/~sas/TruckPictur...tallation.html
Southpa
1970 GMC 1500 Custom
Victoria, BC, Canada
Original 350/TH350
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 03-22-2002, 05:51 PM   #3
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Post
Yea, that is a good how too article. I did the same on mine drilled out the rivets and shortend it by 5".
68chevy, 95step bed, euro taillights, fastbags, fully shaved, phantom grill, 350 with a small huffer, TH350, 12bolt Auburn posi 4:11's......... 95 Chevy Tahoe (PHATHOE) all mouldings and emblems stripped, 4/4 drop, Niche Bellas 18's, billet grill, Euro taillights, clear corners, billet antena & wiper covers, leather interior, Pioneer cd, alpine amp, Rockford 15's.......... 97 CBR 900 RR, everything that is aluminum was polished or powdercoated candy purple, 6 color change Chameleon paint at $300 a pint(ouch), custom one of a kind under seat exaust, hand cut decals, runs 11 flat at 126mph FUUUUUUUUUUUUUUN!!!!!!!! ............ my toys at http://communities.msn.com/NSANE68Tr...s/shoebox.msnw
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 03-22-2002, 06:00 PM   #4
69sixpackbee
Post
Okay, but, will the "guts" swap??
BTW, thanx as always from the best Chevy guys on the net!!!!
Old 03-22-2002, 07:02 PM   #5
john
member #16
john's Avatar
Post
I think the housings are different, dont know about turn sig sw.
67 SWB 350eng th400 3:07 posi tilt&tach PS/P/Disc Brakes old air a/c P/W keyless entry gaylord lid 70swb project truck 350/th400
john is offline   Reply With Quote
Old 03-22-2002, 09:21 PM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
Post
Everything should fit, but it is easier to just get the adapter($10-12) that will connect the flat plug of the van column to the C-shaped plug of our trucks. That's what you do if you buy a replacement turn signal switch anyway.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
