Old 01-24-2007, 10:55 AM   #1
JESSEGALLEGOS
JESSEGALLEGOS's Avatar
One side lower then the other?
Now that everything has settled I measured the front this morning and the driver side is 3/4" lower the the passenger side. I measured it on a level ground. Any of you have this problem? If so what did you do to fix?
I was thing of using one of these in the driver side.
http://images.google.com/imgres?imgu...lr%3D%26sa%3DN
1982 BLAZER 2WD
http://img.photobucket.com/albums/v7...t/145c37fd.jpg
JESSEGALLEGOS is offline   Reply With Quote
Old 01-24-2007, 07:44 PM   #2
pcmcobra
pcmcobra's Avatar
Re: One side lower then the other?
you got dual tanks?
pcmcobra is offline   Reply With Quote
Old 01-24-2007, 09:27 PM   #3
edman87
junk collector
How much do you weigh?
I had to ask, I always find it funny when someone in the 400 + club makes a toyota lean to 1 side.
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 01-24-2007, 09:40 PM   #4
JESSEGALLEGOS
Good call but I wasn't in the Blazer when I measured it plus I only weigh 160 lbs.
you got dual tanks?
Single tank. Did Blazer ever have dual tanks?
1982 BLAZER 2WD
Old 01-24-2007, 09:58 PM   #5
wedgemon
wedgemon's Avatar
They ALL tend to favor leaning on the drivers side. Unless it gets driven with no-one in it.
The body mounts get a bit mashed down more often on that side.
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
