Old 02-03-2007, 03:05 AM   #1
longhorn71
longhorn71's Avatar
blazer is back under way
after a little break from the truck(wifes car wreck)I got started on the truck again
this is what it started out as.
350/th-350 base blazer with a lot of hidden sins under some bad paint work
longhorn71 is offline   Reply With Quote
Old 02-03-2007, 03:14 AM   #2
longhorn71
longhorn71's Avatar
Re: blazer is back under way
the firewall was left red and will be sprayed with under coating during the 6.0l ls1 swap.Cut the fire wall to convert it to a/c.the door striker area was all cracked and broke out so we cut and welded a chunk in from the parts truck.All the trim hole and emblem hole were shaved.the quarter on the drivers side was full of window mesh (GOTTA LIKE P/O )and fiberglass.It was cut out and replaced with steal.The rear floor needs to be cut out and fixed yet.hoping to be in paint for the 20th.then start the ls-1 swap in march
the floor in the rear is so weak the rachet strap is holding the bed sides in to keep the tailgate shut!
Old 02-03-2007, 08:43 AM   #3
Southedisto
River life......
Southedisto's Avatar
AAAHHHH progress sweet progress!
Southedisto is offline   Reply With Quote
