Old 03-22-2002, 05:22 PM   #1
Scott Chadderdon
Post Steering Column/Turn Signals
Sure glad I have this board to address my stupid questions. My turn signal stalk is very loose, it still works. The screw that connects it to white hard plastic part in the steering column (no tilt) has stripped out threads.Any ideas for fixes? Is this the turn signal cancelling cam or the actual turn signal switch, what do I need to buy?
Scott Chadderdon is offline   Reply With Quote
Old 03-22-2002, 07:45 PM   #2
fine69
fine69's Avatar
Post
Just use a bigger screw. Like a wood screw, something with a bite on it. So it wont come loose again. Its what i do.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 03-22-2002, 10:14 PM   #3
chevyman 68 C/10
chevyman 68 C/10's Avatar
Post
The threaded part is not apart of the turn signal cam. Not sure but it may be somthing you can remove and replace. All it is,is a metal sleave that is threaded. Take off the cam and check it out,just remove the two keepers on the far right and release the snaps holding it on. Also if your cam is brittle or damaged they are almost dirt cheap,at the very least easy while you are in there. GOOD LUCK CHEVYMAN 68 C/10
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air.
68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles
68 anniversary no engine long wheel base 400 auto FOR SALE
68 Chevy fleet side long wheel base complete parts truck.
chevyman 68 C/10 is offline   Reply With Quote
Old 03-22-2002, 10:35 PM   #4
DARK OLIVE 72CHEYENNE
DARK OLIVE 72CHEYENNE's Avatar
Post
all that you would need to do is drill it out and retap it... with the next size up... should work just fine good luck
DARK OLIVE 72CHEYENNE is offline   Reply With Quote
