Old 04-14-2007, 12:38 PM   #1
gator2511
gator2511's Avatar
Vortec Head Rocker Stud Change
Well, I just don't feel comfortable with PRESS in rocker studs. Before I put these heads on my truck I wanted to install screw in studs. I'm dead ready and waiting on the Fed Ex truck!
The tools got here and I went right to work. This shot shows the stud puller ready to do its work. On the first few studs the puller was tight going over both studs so I used a small rubber hammer to tap it down firmly. It seemed to get easier after that but I still had to use the hammer to seat the puller on the bosses.
This is the first stud pulled and the puller being used to tap the first hole. I had a problem with only one hole. It wasn't drilled deep enough to accept the new stud and I had to finish drilling it. After you pull the stud, look down into the hole with a light and check the hole for proper depth.
This shows the hole tapped with the little puller at the bottom of the photo. It amazed me how easy it was to pull the studs with this tool and an electric impact hammer. All you have to remember is to stop pulling once or twice and add more washers on the top of the tool.
All the holes are tapped and the new studs are ready to put in. Before I did that I washed all the metal from the tapping process with mineral spirits and blew them down real good with compressed air.
The new studs are in, torqued to 50 ft. lbs and coated with threadlock.
Here are the old pressed in studs.
End view of one of the completed heads. All finished, all done and well, uhmm READY TO ROCK. (Sorry I just couldn't help it)
Of course I wouldn't have even thought about doing this myself without the help from rage'rat638. Many thanks for all the information from all of you.
gator2511 is offline   Reply With Quote
Old 04-14-2007, 01:31 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Vortec Head Rocker Stud Change
see easyest thing to ever did right
just think what the machine shop would have charged
plus you got the tools to do it again and again..
great job brother
rage'nrat638 is offline   Reply With Quote
Old 04-14-2007, 01:33 PM   #3
rage'nrat638
after everbody see's this we could move this to the FAQ
Old 04-14-2007, 02:03 PM   #4
gator2511
gator2511's Avatar
With the right tools its very simple. The thing is, we get in the mind set that all this engine work is "machine" work and some of it really isn't all that difficult to do. That said, I'm not gonna take a rattail file to hone my cylinders. Thanks again.
Old 04-14-2007, 02:41 PM   #5
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Very nice gator2511, IMO it just feels better to DIY too. I agree after a bit send it on to the FAQ's, GR8 TECH so some others that are sceptical about this will give it a try.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-14-2007, 08:34 PM   #6
Rick Mills
Rick Mills's Avatar
Great thread! Learned something new today.
The Fastor Pastor
'68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed:
'70 swb; TH-400 - bagged & shaved. Looking for new engine or parts.
Wife - Original {A Real Classic!}
Rick Mills is offline   Reply With Quote
Old 04-24-2007, 09:55 AM   #7
orange72blazer
orange72blazer's Avatar
What brand studs did you use, do you have a part # .
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is offline   Reply With Quote
Old 04-24-2007, 12:48 PM   #8
Pyrotechnic
Pyrotechnic's Avatar
Great job. Vortec heads become not such a great value when you have to take them to the machine shop.
Pyrotechnic is offline   Reply With Quote
Old 04-24-2007, 09:58 PM   #9
gator2511
gator2511's Avatar
I used Mr. Gasket part #720-1076. $29.99 at Jegs.
Old 04-25-2007, 09:07 AM   #10
rage'nrat638
Thumbs up Re: Vortec Head Rocker Stud Change
glad you got your pictures working again.
the other day all i saw was x's
great job again
