06-05-2007, 12:25 AM | #1 |
gear shift indicator light ???????
doesnt the stock auto column gear indicator have a light in it so you can see what gear you got it in ? if it does mine dont work ..... any tips guys ?
bob |
06-05-2007, 12:30 AM | #2 |
Re: gear shift indicator light ???????
Is it a tilt?
Non tilt - had a fiber optic cable that mounts to the rear of the gauge cluster. They tend to break. Tilt - has a lightbulb under the indicator plate.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
06-05-2007, 10:26 AM | #3 |
Licensed to Thrill!
06-05-2007, 11:36 AM | #4 |
my truck has a tilt column what all is involved in changing the bulb and what number is the bulb so i can have it there ready to reasemble.
thanks bob |
06-05-2007, 11:39 AM | #5 |
Probally be a 94 bulb and a rubber boot that turns into the back of the indicator. Not too sure though I have a 80 Camaro column
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
08-27-2009, 10:31 AM | #6 | |
Redefining LowBudget
wow search worked thats why I brought back an old post ...Kool |
08-27-2009, 10:39 AM | #7 |
Between Trucks...
Plugs in to one of the dash lights. There should be a bulb holder on the end of the fiber optic cable.
Beat it to fit, Paint it to match... |
08-27-2009, 11:34 AM | #8 |
- it should be a funky white connector on one of the 4 dash lights that stay on all the time with the lights.
Those would be the 4 that go across the back of the cluster - in the middle... if this isn't clear - I can get/find a pic |
08-27-2009, 01:02 PM | #9 |
I guess a pic would help?? I changed dashs but saved most of the bulbs from the other one so I will check to see what I have but I think?? I understand
08-27-2009, 01:09 PM | #10 |
Moderator
2 screws to take off the indicator housing. You will see a light bulb in there with a green filter on top of it. Remove it carefully and replace with a new bulb. IIRC it is an 1187, or something like that. It will be stamped on the bulb. Be very careful not to break the shift pointer when removing the housing.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 08-27-2009 at 01:10 PM. |
08-27-2009, 01:14 PM | #11 |
sorry dude I have the firbe optic one but thanx
On a side note I found the bulb fixture I did save it hard to believe isn't it??? for a long time I was trying to hook a ground wire for the dash to it ( yea I know dumbass) but I was working upside down duhhhhhhhhh....I'm going to put it in and see if it works tonight...Thanx again you guys got me straightened out!! I might even hook my tack light up..won't that be special!!!! |
08-27-2009, 01:26 PM | #12 |
Moderator
I was answering the question that the original poster asked. Now I see that was 2 years ago
You can just post a question yourself, no need to ask in an old thread.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
08-28-2009, 09:32 AM | #13 |
I try to save space and use the search to get answers before I start a new post everytime..most dumb ?'s I ask already have been answered anyway....
on a side note it works now and yes even hooked up te tach light to |
08-28-2009, 03:34 PM | #14 |
Moderator
That's a good idea, but when you can't find the answer in an old thread, just post your question. It saves confusion. Glad to hear it works now!
06-18-2020, 06:03 PM | #15 |
Shift Indicator Fiber Optic Cable
Sold as Each Part #: 7850 1967-1970 Chevy Truck or GMC truck https://hhclassic.com/images/F77090549.jpg |
06-19-2020, 10:42 AM | #16 |
Msgt USAF Ret
here's the fibre optic light
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
07-13-2022, 10:40 PM | #17 |
Reviving an old thread to ask: how the heck do you route this wire from the shift indicator housing down the column and up to the cluster?
There’s a small conduit for the blinker wires at the bottom of the column but I have now idea how to get the wire down and into there without taking apart the whole column. Any help is much appreciated!
Have mercy, I'm recovering from my 4x4 addiction. |
07-14-2022, 01:56 AM | #18 |
The fiber optic line routes through that conduit along with the turn signal switch wires. You should be able to snake the fiber optic line down through the shift indicator pointer hole and have it pop out down below where the conduit is located. You will have to slide the conduit down toward the dash first.
07-14-2022, 09:58 AM | #19 | |
For anyone reading this in the future, it's actually pretty easy. The key to a) remove the two covers below the steering column in front of the parking brake b) remove or slide the conduit cover, which is held in place by two bendy prong thingys and in my case some tape (original?). Gently bend back the bendy prong thingys and slide the cover out of the way and then route the wire down through the opening then grab it at the bottom and have it follow the blinker wires down and up to the back of the gauge cluster where it clicks into the light for the speedometer. Then do some stretches because working under the dash probably made your back hurt...
