Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 07-07-2007, 07:30 PM   #1
shifty
Questionable
shifty's Avatar
HOW TO: Poor man's no-weld gas cap delete
This thread contains many posts and will show an inexpensive way to give a semi-stock appearance to a truck with the gas tank removed from the cab.
This is not originally my idea - I owe thanks to another board member ('uncle') for showing me a truck that had a similar mod from the dealer, I just took it a step farther using a stock cap and took photos of the process.
Approximate cost for this modification is $10, tools required are only a drill, file (or rotary tool) and a wrench.
Parts you'll need:
- Stock gas cap; I used Napa part BK 7031220
- 5/16" Carraige bolt that is 2.5" long (20¢ at Hardware store)
- Two nuts to fit that carriage bolt (5¢ each at Hardware store)
- 5" long piece of heavy steel bar; I used 1/4" thick steel that was 1.5" wide
- Optional: Stock gas tank filler-neck gasket, if you don't already have one installed
Here's the gas cap:
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline
Old 07-07-2007, 07:32 PM   #2
shifty
Questionable
shifty's Avatar
Re: HOWTO: Poor man's no-weld gas cap delete
If you flip the gas cap over, you will see what it looks like in the first picture below. In order to properly drill the cap, I had to cut off the first dimple of the cap, as shown in the second picture below. A cheap and easy way to do this is to shove the cap bottom-first into a bench grinder till it's gone
(I like to make sparks)
(Be sure to wear safety glasses)
shifty is offline
Old 07-07-2007, 07:35 PM   #3
shifty
Questionable
shifty's Avatar
At this point, you should see the steel that holds the bottom assembly to the cap. I found it was best to drill starting at the bottom. You'll need to make a 5/16" hole all the way through the cap - I used a step bit (aka 'uni-bit') to perform this feat.
Drill all the way from the bottom through to the top. I suggest leaving the hole in the top of the cap small so it will still 'catch' the square provision on the carriage bolt - this is why I chose a step bit rather than a standard drill bit.
shifty is offline
Old 07-07-2007, 07:37 PM   #4
shifty
Questionable
shifty's Avatar
At this point, you should be able to slide the bolt through the cap.
You will need to use a file or rotary tool to make a "square" opening in order for the carraige bolt to fit flush against the top of the cap. This is easy - I didn't take pictures of the square hole in the top, but you'll figure it out.
Pics of the bolt inserted and sitting flush:
shifty is offline
Old 07-07-2007, 07:38 PM   #5
shifty
Questionable
shifty's Avatar
Next, get a piece of steel stock. This will be used to brace the cap from the inside of the cab as shown in the next post.
I used a 5" wide piece of 1.5" wide 1/4" thick steel. I just happened to have it laying around - use whatever you want, just make sure it won't bend under stress.
I drilled a 21/64" hole dead center of the piece. You could use a 5/16" hole if you wanted, I just wanted some breathing room and had the odd sized bit laying around.
shifty is offline
Old 07-07-2007, 07:42 PM   #6
2bits
2bits's Avatar
I would love to see a thief trying to take that cap off to steal some gas too haha!
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline
Old 07-07-2007, 07:42 PM   #7
shifty
Questionable
shifty's Avatar
Finally, I am assuming you already have a gas tank filler-neck gasket on your truck. If not, you'll need to buy one. I got mine from GMC Paul's (www.gmcpauls.com). It was somewhere between $5-10, and their service is great... I'd buy 20 more if I had a use for them
Put a small bead of silicone or similar sealant around the bolt to prevent leaks from happening (thanks, cdowns!). Slide the bolt into the cap, and place the cap over the gasket as shown below in the first picture. From behind, slide the bar over the bolt, then tighten down one of the nuts on the back end. once the first nut is tight, take the second nut and tighten it on top of the first one, then tighten the two nuts by twisting opposite of each other. This will keep the nuts from falling off by locking them together. Double-nutting is a great way to secure stuff.
shifty is offline
Old 07-07-2007, 07:44 PM   #8
shifty
Questionable
shifty's Avatar
Here is the end result: A semi-stock looking cover for your gas-hole (har har).
It doesn't look that bad up close or at a distance. It's a cheap solution for me to get by until I can weld everything up properly.
Total project time was 1.5 hours, with beer, and I made everything up as I went. Without beer, after reading this tutorial, you could probably finish the job in less than 45 minutes. I personally prefer using the beer method if you are of age, but remember - all things in moderation!!
Enjoy
shifty is offline
Old 07-07-2007, 08:25 PM   #9
uncle
Looks better with a painted (to match body color) cap though. WINK WINK! Couldn't resist.
uncle is offline
Old 07-07-2007, 09:28 PM   #10
71swb4x4
71swb4x4's Avatar
I did something similar.
I put the cap on the outside, and then used a 5" bolt (anything 5" would work) and used two cable ties to attached the filler cap to the bolt. The bolt is the long way just like the steel bar above, and each cable tie goes around one of the tabs on the filler cap. It does the same as Shifty's, except you don't have a bolt going through the cap, and all you have to find to make it work is two cable ties and something 5" long.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline
Old 07-08-2007, 08:35 AM   #11
mnunn454
mnunn454's Avatar
I also did something similar.
I drilled the cap on an angle to accept my automatic power antenna. Then I cut the neck off the no longer needed tank and split the inside end of it into about a dozen "fingers", bending them outward to act as a securing lip. Still need to touch up the paint around the grommet, but here's what the result looks like so far. Works like a champ.
My goal was twofold. Addressing the tank delete hole, plus having a "stealthy" antenna without requiring all the body and paint work of frenching in an antenna mount. Most people just glance at it, recognize it's unusual and keep moving, so I'm pleased with the result.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline
Old 07-24-2007, 01:17 AM   #12
shifty
Questionable
shifty's Avatar
Re: HOW TO: Poor man's no-weld gas cap delete
PS - can a mod move this to the truck FAQ section please (thanks, krue )
here is a picture of a "from the dealer" modification from a truck that 'uncle' purchased recently
shifty is offline
Closed Thread
