04-28-2002, 06:55 PM | #1 |
I need opinions.
I am getting opinions on different parts for my truck before I start on a restoration. I have pretty well figured the engine, Performer or Performer RPM manifold and carb, ported stock heads, K&N filter. However, I need help in selecting the right exhaust system. I am planning on Flowmaster mufflers, but what about headers, etc.? I was just wondering if I can just clean up the stock ones and they will work sufficiently? What do you guys use on your trucks?
Thanks.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
04-28-2002, 07:22 PM | #2 |
63 corvette 2.5" exit ram horns are nice and not expensive and are quieter and dont rot out and etc, etc
good luck ------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 -71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not) -84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,, -84 Firebird SE 2.8L T-5, rod knocking, dammit,, -82 Firebird 350 4bolt (TBL)/TH350, not running, dammit... buy/sell/hoard/trade most any GM vehicle parts of any kind -parting out: '81 Cutlass Supreme Brougham *Paint is overrated © RSS Enterprises 2000 |
04-28-2002, 07:26 PM | #3 |
its all about the +6 inches
I gotta say, I like my hooker super comps a lot. Nice fit, nice exit angle, only one plug is a pain to get to.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
04-28-2002, 07:46 PM | #4 |
I also reccomend the Hookers.I have a set of Comps.......again , nice exit angle,& they dont hang too low on my lowered truck. On the intake, I would use the performer....unless you are in the 9.5- 10 to1 range on compression,& have a healthy cam. Then go with the perf rpm. Good luck....69 longhorn.
http://community.webshots.com/user/hotrodhorn |
04-28-2002, 07:53 PM | #5 |
I have a BBC and I run JETHOT HEADERS there ceramic coated and look as good as they did the day I put them on.And I used the cooper seal gasket top and bottom.If you got a good solid set of headers you could send them to JETHOT or AIRBORN and get them coated,I think this would be the cheapest way to go.
------------------ BIG ORANGE 1971 SUBURBAN 1970/90-Little Buck's Truck (ONE DAY) USED TRUCK PARTS 4 SALE
Things happen for a reason! |
04-28-2002, 08:10 PM | #6 |
I'd run the RPM if you plan on a cam with more than 220 deg duration at .050 and maybe the new square bore performer if you are going to run a Holley. If you want to go Q-jet and stay below 5500 rpm, the regular Performer is just peachy. Unless it is 400+ hp (be HONEST here) I'd run the 2.5" 'vette manifolds and port match them and clean up the collector area. Other than that, I like Heddmans since they are one of the few that I am 100% POSITIVE will work with a 67-72 and NOT have to modify the clutch linkage. If you've got an auto, the Hookers or Thorleys are good choices as well. FOr what it is worth, I replaced my Heddmans with the Rams Horns on the Jimmy. I also replaced the 2 1/4" exhaust with 2 1/2" at the same time and the truck has never run as well. And it is QUIET both under the hood and outside with Walker Hemi Super Turbos.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable
04-28-2002, 09:27 PM | #7 |
Oh great, now I have more to choose from. Ram horns, heddmans, Hookers, Jet hot. I'm glad this is in the future so I have lots of time. Be honest? No it is not currently 400 hp, maybe someday? I don't plan to run a Holley, I have heard way too many bad things about them.
------------------ 1969 Chevrolet C/10 (Camille)-getting her this summer!! 1999 S-10-reliable transportation 1988 Isuzu Trooper II-gotta love old 4WDs Check out this site! http://www.60schevytrucks.com/forums/index.php?s=&referrerid=4
04-29-2002, 12:03 AM | #8 |
go bucks!
got a set of dynomax ceramic coated headers on mine.very good thick flanges at the block wont warp.just be sure to spend the extra dough on good manifold gaskets(ultra-seal by mr.gasket are good)and a good set of dead-soft copper or aluminum collector gaskets.are extra in price but trust me,well worth it.
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
04-29-2002, 01:57 PM | #9 |
Mike C, I got the Heddmans for the 1970 C-10 I'm working on, and I DID have to modify the clutch. The "cross tube mounted to a ball on the frame, and one on the engine. The ball on the engine was mounted to a bracket that bolted to the engine, which positioned the ball on the engine side directly behind one of the header tubes. I had to remove the engine bracket, and buy a pivot ball that screwed directly into the engine block. that works, but puts the cross tube at a fairly severe angle. Also, one tube of the Heddmans hit the frame on both sides.
04-29-2002, 10:39 PM | #10 |
I had a 4x4 which doesn't have the plate, the ball is on the block. Maybe they got you the wrong part #?
04-30-2002, 07:51 AM | #11 |
I did not have the same luck with Jet Hot. After 2 years I had them powder coated yesterday with a heat treated powder coating. they look great now but will see how these hold up. My Jet Hotted headers were covered with suface rust and rusting bad on the edges of the flanges. I do believe I would recomend Airborne. Ive heard the guy that has it came from Jet Hot. I do know for fact the headers I bought from Jet Hot were used. (Hookers).
------------------ 67 stepside 4x4 Owensville MO mudder67@hotmail.com |
04-30-2002, 04:17 PM | #12 |
I have Hedman and had absolutely no problems,good fit,no mods needed,no leaks,good sound
------------------ 1968 SWB Stepside, pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,3 bolt seatbelts, original i6 and wood bed, seat from an 89 Chevy, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,WORK IN PROGRESS,Daily driver, 20 MPG, Freeland MI
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!! |
