Old 04-29-2002, 08:53 PM   #1
50272
Post help on gas tank
Putting blazer gas tank on short bed. Saw pictures on here one time that someone had. Any help on finding this would be appreciated.
50272 is offline   Reply With Quote
Old 04-30-2002, 05:10 PM   #2
Kas68c10
Kas68c10's Avatar
Post
Does it fit ? I read on the board our short beds were too short for a blazer tank. I used one from an old camaro I think. Gmcpauls website has a tech tip section and if you can search the archives you should find lots on it. It is a common topic.
1968 SWB Stepside, pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,3 bolt seatbelts, original i6 and wood bed, seat from an 89 Chevy, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,WORK IN PROGRESS,Daily driver, 20 MPG, Freeland MI
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
Old 04-30-2002, 05:35 PM   #3
John Fabris
TOTY 2006
John Fabris's Avatar
Post
I have some photos on my web page of a gas tank that I got from a 62 suburban. Was a bolt in job after removing the spare tire crossmember. Still have not started the project of running the filler over and up into the rear stake pocket and out the tilting taillight. I know a couple of guys are waiting for me to do this, May is the month I will get it done, Danit!!!
John Fabris
john.fabris@autodesk.com
1967 C10 SWB FleetSide Web Page
1971 K5 Blazer 2WD (basket case, but give me two year or so.)
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 04-30-2002, 06:05 PM   #4
50272
Post
the fitting of the gas tank is not what I need.I am wanting to run the fill neck behind the running light on the drivers side bed. Sorry I should have been more clear on this. I saw some pictures on here I think on how a guy did it with s-10 filler neck. Any help on this would be appreciated
Old 04-30-2002, 06:13 PM   #5
CARS4567
Post
GO TO WES'S BOARD AT CLASSIC HEARTBEAT-
CARS4567 is offline   Reply With Quote
Old 04-30-2002, 06:14 PM   #6
50272
Post
Thanks.
