04-30-2002, 09:19 AM | #1 |
Location: Bondurant, IA but in Worcester, MA for school
Wheel Help Please
None of the 10" wide rims are with the amount of back spacing people on the board are recomending (5 to 6"). I was looking at Eagle Alloy wheels and their 16x10" wheels have a backspacing of only 4.5". Do I have to get them custome ordered or can I just tub the wheel well and make them fit?
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
04-30-2002, 11:14 AM | #2 |
well if you go overboard with the backsapcing then you iwl have tire sidewall rubbing on inner wheel tubs problems in the rear and problems at full tuen in the front, tires will hit inner wheel fender and maybe bumper bracket depending on diameter of tire,
its tircky, different spacing with different tire tread widths, lots of measuring and calculating and mocking up, suspension jounce will affect decision of tire size and spacing also good luck ------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 -71 C-10 350/CH465/3.07, basketcase literally, am assembling now -84 Z28 5.0L/700R4/3.73 daily driver -84 Firebird/SE 2.8L/T-5/3.73/engine bad, dammit,, -82 purple Trans Am, ram hood, junk305/good THM200C **I buy/sell/hoard/trade most any GM vehicle parts of any and all kinds -parting out: '81 Cutlass Supreme Brougham *Paint is overrated © RSS Enterprises 2000 |
04-30-2002, 11:48 AM | #3 |
Got 20's????
6" backspace would about rub on the wheel well, maybe 1/4 gap maximum.
------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota WANTED: Drop Spindles F/S: rebuilt Turbo 400 & Aluminum wheels w/ tires
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
04-30-2002, 11:53 AM | #4 |
So will the 4.5" backspacing that comes on the Eagle Alloy 16x10" wheels be good enough for the rear of my truck?
04-30-2002, 12:31 PM | #5 |
If you run a 10" wheel w/6" back space the wheel tubs will need to be widend. The standard offsets offered will work if the truck is @ stock height but if you've lowered it custom offsets are sometimes necessary. I had to order 2-pairs of 15x6" standard torq-thrusts when i did my 93 x-cop/stang. Then I widend 2 to my specs because of the limited offsets in that size so that everything would fit nicely. The final fit was dead-on & I've seen others that just ordered whatever was available & put them on & they didn't fit/look half as good.
04-30-2002, 12:43 PM | #6 |
THe truck will be lowered but if I tub the wheel wells will I still have to get the wheels custom made?
04-30-2002, 06:54 PM | #7 |
Thats mostly going to depend on the wheel manufacturer. Some companies offer standard sizes/backspacing while others cost so much the custom features are included.
[This message has been edited by SCOTI (edited April 30, 2002).]
